05-30-2012 10:56 AM - edited 03-16-2019 11:24 AM
I am looking for a way to setup bulk speed dial in CUCM 8.5 for 400 numbers. Does CUCM has search option available for speed dial? I want to setup all phones at sites with speed dial that lists all 400 numbers. Cisco only support upto 200 numbers for abbreviated dialing.
05-30-2012 10:58 AM
Configure them as translation patterns instead, it's easier if you want all phones to use the same numbers.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
05-30-2012 11:02 AM
Does that mean for each number I need translation pattern? If users want to serch specific number, how can be done? Do you have any steps or document you can refer to setup .
05-30-2012 11:04 AM
Yes, each DN is a TP
No way to search for those
You just need to refer to the TP config, either online or use the help -> for this page on CCMAdmin when in the TP page.
java
