Speed Dials
silex
I want to be able to add 2 speed dials with a configured number, to over 300, 8811 phones, when they auto register.
I have set the universal device template to the template I want and that is fine. I would like to be able to have the dialled numbers pre populated.
is there a way to do it?
Jaime Valencia
Have you tried creating a new phone button template, applying it to the universal device template, and adjusting them under phone button configuration??
java
if this helps, please rate
Jaime Valencia
java
Yeahm that was it. I missed that last part. many thanks for the steer
