06-08-2017 07:26 AM - edited 03-18-2019 12:15 PM
SSLV3 need to be disabled in Network devices(from routers, switches, firewalls, ip phones etc)
I like to know what are the changes need to be done as part of IP Phones or in VOIP environment.
How to Disable SSLV3 in IP Phone? Can anyone suggest the process its Urgent.
06-08-2017 07:36 AM
Phones do not have a switch to choose which ciphers to use, or which TLS versions to use.
See these bugs
CSCvd66630
CSCus33571
07-10-2017 07:30 AM
We found some of the IP phone SSLv3 enabled while scanning so how to disable those ?
and how to check SSLV3 option enabled in callmanager or not?? and how to disable it any idea?
So if we should not make changes in Switch then is it via ASA?
07-10-2017 07:51 AM
As I already mentioned, there is no way to enable/disable SSL versions on the phones, nor in CUCM (for the phones, or for CUCM).
