System Message on Telephone Display
chris.wilson
Does anyone know if it's possible to customize the system message by individual phone or can it be eliminated altogether?
acampbell
Chris,
Can you provide some more information.
What system is your phones using
CUCM, CME etc
Alex
Regards, Alex. Please rate useful posts.
Alex,
It's a UC540.CCA 3.1(1) 8.2 software pack.
The system message is an all phones feature.  If you want to disable it I think you can just insert a space as the system message, if not then perhaps something like a period which would mostly go un-noticed.
Keith
Hi Chris,
Sorry for the delay
As Keith shows.
Either using cli
conf t
telephony-service
system message . (Or a SPACE you need to use a single character)
Or from the GUI
Configure ---> Sytem message
PS,
conf t
telephony-service
no system message
This will show the DEFAULT CISCO SYTEM MESSAGE
So that wont do what you want.
Alex
