T.38 NSE switchover issue
Good day!
I have issue with t38 nse based switchover - no switchover occurs with event 202
topology:
telco----pri-----ISRG2(MGCP)-----cucm------vg224(SCCP)----sg3fax(no ecm,forced 9600baud)
mgcp cfg:
no mgcp fax t38 inh
no mgcp fax t38 ecm
mgcp fax t38 nsf 000000
mgcp fax t38 gateway force
MODEMPASS disabled.
vg224 cfg:
voice service voip
fax protocol t38 nse force version 0 ls-redundancy 0 hs-redundancy 0 fallback none
debug info from vg224:
  18:11:51.508  :          s=DSP d=VoIP payload 0x64 ssrc 0x1DF0 sequence 0x15FF timestamp 0x4B8672E7
  18:11:51.508  :          Pt:100    Evt:200     Pkt:00 00 00  <Snd>>>
  18:11:51.520  :          s=DSP d=VoIP payload 0x64 ssrc 0x1DF0 sequence 0x1600 timestamp 0x4B8672E7
  18:11:51.520  :          Pt:100    Evt:200     Pkt:00 00 00  <Snd>>>
  18:11:51.536  :          s=VoIP d=DSP payload 0x63 ssrc 0x25AF82ED sequence 0xDD8 timestamp 0x44276827
  18:11:51.536  :  <<<Rcv> Pt:99     Evt:202     Pkt:00 00 00
  18:11:51.540  :          s=DSP d=VoIP payload 0x64 ssrc 0x1DF0 sequence 0x1602 timestamp 0x4B8672E7
  18:11:51.540  :          Pt:100    Evt:200     Pkt:00 00 00  <Snd>>>
  18:11:51.544  :          s=VoIP d=DSP payload 0x63 ssrc 0x25AF82ED sequence 0xDD9 timestamp 0x44276827
  18:11:51.544  :  <<<Rcv> Pt:99     Evt:202     Pkt:00 00 00
  18:11:51.564  :          s=VoIP d=DSP payload 0x63 ssrc 0x25AF82ED sequence 0xDDB timestamp 0x44276827
  18:11:51.564  :  <<<Rcv> Pt:99     Evt:202     Pkt:00 00 00
Issue solved by migrating port from sccp to mgcp.
