03-14-2011 10:18 AM - edited 03-16-2019 03:56 AM
We are using Cisco 7940 VoIP phones. We have recently upgraded to Windows 7 x64 and Office 2010. The TAPI integration that was provided by our VoIP vendor no longer works. Does Cisco have a driver that will allow our staff to dial the phones from the Outlook?
Thanks.
03-14-2011 10:22 AM
do you use Cisco Unified Communications Manager Express or Cisco Unified Communications Manager?
Kind regards,
Marcel Ammann
03-14-2011 10:31 AM
We don't use either. We don't have our own server or PBX. We use a hosted solution and they have told us they have nothing to help us. I found it hard to believe that there is no good option for those who want to use TAPI integration.
03-14-2011 10:48 AM
Do you know, or can you find out, what version of what service (CUCM / CCME) your provider is running, this is crucial to determining if there is an applicable TAPI client for your OS.
03-14-2011 11:16 AM
I will email our provider and try to find out.
