TCL IVR dtmf events (ev_digit_end) not received when legs connected
A C
on c8000be Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.6.6a tcl script does not receive ev_digit_end events when two legs are connected.
Events are correctly received when legs are not interconnected.
Similar script works 100% on older versions/platforms (ISR 16.12.2s)
Any hint?
Is there a bug around?
Thank you
A C
Upon further investigation, it works on a POC script, so I definitely think there's some oddities between version, but when properly programmed, the features appears to work on said version.
Thank you!
