11-26-2014 11:20 AM - edited 03-17-2019 01:06 AM
Facing problem in fresh installation of Cisco unity connection in MCS7825 H3
Installation logs attached
11-26-2014 12:24 PM
what is the unity connection version you are trying to install ?
it seems this unity connection version is not compatible with this hardware
Anas
don't forget to rate the helpful posts
11-26-2014 12:34 PM
Generally hardware issues are the problem. If you are using a VM environment I would suggest using the .ova template to ensure everything is setup correctly.
11-26-2014 08:18 PM
Hi Anas,
The CUC version is 8.5.1 ,Installing in MCS7825 -H3
I have gone through the compatibility matrix and its compactible .
Nishad KI
07-03-2024 12:11 AM
I have encountered similar problem today, I skip the 'Media Test' part and that worked.
