Transcoder not allocated for sip call
hi
I have a xcoder to convert between g711/g729.
in my test, a 7940 (sccp) and 8945(sip or sccp) in a region that only allows g729
the voip is a sip trunk that only accepts g711
if i call from 7940, the call is successful because is allocating the mtp xcoder to transcode the call
if i call from 8945, the call fails because is not allocating the mtp xcoder
i aslo have a sip trunk to another cucm cluster that is sending calls to my cluster using g729. calls fail too
any idea?
attached some logs too
15 Replies 15
any idea how to bring the xcoder into the picture? thanks
