transport tcp tls v1.0
Ela_68
Hello everyone,
I'm trying to configure a Gateway.  As i try to enable TLS v1.0 on the router, I become an error that "t"ls is unknown by the router.
Can any one help me in this case ?
Best Regards
Ana
5 Replies 5
Jaime Valencia
Do you have the security license?
java
if this helps, please rate
Yes. I have the security license as well.
To start tls1.0 isn't secured anymore. The recommendation to start with
TLS1.2.
What router are you using and what is the command syntax.
**** please remember to rate useful posts
ISR 4331 is the router.
If you are on IOS-XE 16.5 and above you can use the command ip http
tls-version
*** please remember to useful posts
