Unified Unity Questions
jbillingsley
Is there a place on cisco.com to check if a particular patch/rollup is considered stable in a Unified VM environment. In my case, the Exchange Server is separate from Unity, but I don't want to break anything or cause issues when applying patches to my Exchange Server. I've always rebooted Unity after applying changes to Exchange, is this necessary?
Specifically, I want to apply Exchange 2007 SP1 Rollup 6 to my E-mail Server and want to know if this will cause any issues or if I should also be updating my Unity Server at the same time.
Thanks for any advice
Jaime Valencia
the list is here
Software Installed by the Cisco Unity Server Updates Wizard in 2009
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/updates/wizard/2009cuupwz.html
java
if this helps, please rate
java
Thanks java, that's a good resource. I've never done that before. Should I expect something to break if I install updates on the Exchange server and don't do anything to the Unity server?
no, you can install only the applicable updates on each server or just install updates on 1 server, your choice
java
java
