Unity 8.0, Error: The Template Persistent Cache initialization failed for Application Pool 'DefaultAppPool'
Hi all,
I have a Unity Server 8.0 Build 8.0 (3.3) with Windows Server 2003 SP2, Event Viewer has given me the following error:
Event Type:      Error
Event Source:   Active Server Pages
Event Category:           None
Event ID:         5
Date:                8/2/2011
Time:               10:01:01
User:                N/A
Computer:        SVR-UNY-02
Description:
Pool 'DefaultAppPool' because of the following error: Could not create a Disk
Cache Sub-directory for the Application Pool. The data may have additional
Cisco I found this link, but for Unity version 7.0:
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps2237/products_tech_note09186a0080b24d03.shtml
I wanted to know if anyone has applied it at some point, and the result.
Thanks for the help.
Good on you and pls mark this question as answered if you don't mind
Jing Hua
couple of our customers did same solution and it worked for them (not unity 8). There is also a MS link for it as well so it shoud be ok:
http://support.microsoft.com/kb/332097
Hi all,
Problem solved.
I applied the solution of Cisco Unity 7.x, for all ok.
Thank
