Unity Bulk Edit Tool
Limitless1801
I am trying to use Bulk Edit to change a few settings in a bunch of subscribers at the same time. Some of the setting I want to change are:
Greeting options
  - Send caller to
  - Repromt the user after this...
  - Number of times to repromt
Caller Input options
  - Unchecked "allow users to ...."
  I don't get any errors but the settings are not applied. Any idea what's happening?
  Thanks in advanced. RG
yahsiel2004
Level 7
Level 7
What version of Unity?
HTH Regards, Yosh
We are using Unity 7.1
yahsiel2004
Level 7
Level 7
Are you able to make these changes manually on the subscribers? I would verify that there are no DB issues.
HTH Regards, Yosh
