unity connection 9.1 and cobra import login error
Yazen Alaa
Dear All
I have Unity connection 9.1 , i want to import Data by cobra tool , but after put the username and password in unity connection login give me error as showing in the files , i did restart for database proxy service , i follow the steps , but still i have faced the same error , my laptop in 64 bits (cobra tool is installed on it)
Note 1: i got the Backup from unity version 4.0(5) by Cobra tool , i want to download it to unity connection version 9.1 (separate server) , it is upgrade steps
Note 2: i used cobra tool on my laptop " cobra import for unity connection 7.x and later " .
How to solve this ?
thanks and regards
You can download from below link
http://www.ciscounitytools.com/Applications/CxN/InformixODBC/InformixODBC.html
Install it in your PC.
Rate all helpful post by clicking stars below the answer.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
7 Replies 7
ronpatel
Level 8
Level 8
HI
Have you installed the ODBC drivers.
Ronak Patel
Hi Ronak
No , from where can i install it ? and which one exactly i have to install ?
thanks for Quickly reply
Ronak Patel
Dear Ronak
I tried to download on my laptop but give me " connecting " then nothing , i used Firefox and Internet explorer and both the same problem then i cant use IBM link becasue i dont have IBM ID , what you think what is the problem exactly ? my laptop is win 7 64 bits
I am able to download it from the link. Please try another laptop and see if you are able to download it. Or see if your company firewall not blocking the downloads.
Ronak Patel
Hi Ronak
Any updates plz ?
thnx
you mean these
1) IBM Informix Client SDK Install 3.50 TC9 for all 32 and 64 bit Windows                 Systems  Download                 Now (ZIP                 file - unpack and run install)
2) IBM Informix Client SDK Install 3.70 TC5 for all 32 and 64 bit                 Windows Systems.                                  Download                 Now (ZIP                 file - unpack and run install)
My windows is window 7 and 64 bit(my laptop is HP) , which one i will take 1 or 2  ??
