Unity connection CLI command
dihraj.achhra@vodafone.com
Frequent Visitor
Frequent Visitor
Looking for Unity connection CLI command to create user without mailbox
Jaime Valencia
AFAIK there is no such command, you either use the GUI or the APIs.
You can confirm by reviewing the CLI reference documentation.
java
if this helps, please rate
Do you have API details?
All API documentations is over at DevNet
java
