UnityDirSvc Domain acct Unity 5.0
Hi NetPro's,
What should be the specific rights at the domain level for the UnityDirSvc account? Our unity 5.0 server is not a domain controller... I can't find reference in the docs to this specifically
Getting an access denied error, from the AvDSAD service when trying to add PhoneView permissions to a subscriber, and it looks like it may just be a domain permission problem.
Thanks much
Jaime Valencia
if you want a list of permissions go to www.ciscounitytools.com and look for the permissions wizard, there is a link on the bottom outlining what permissions are set by the tool for each account
java
if this helps, please rate
java
