Updating phones using BAT
I want to update the description field on all our phones ( 2000+).
I've been trying to figure out how to do it by using BAT.
I have a CSV file containing device names and the new text for the description field.
Can anyone point me in the right direction?
We are running Call Manager version 7.0.111000-2
Thomas
5 Replies 5
Stuti Desai
You can do it the following way:
On the call manager administration page, Go to
Bulk administration-->phones-->update phones-->query
Just click find to select all the phones and do NEXT.
There you will find description field where you can change it for all.
stuti
Hi Stuti
Thanks for your answer. But as far as I know your suggestion would give all our phones the same description and that is not what I'm loooking for.
The phones should all have different text strings in the description field.
Thomas
Do the Bulk Update with custom file, and include the phone name and field you want to change.
Hi seaman0555
Sorry for my late answer.
Maybe I'm blind. But I can't seem to figure out where?
Thomas
