Upgrade CUCM 10.5 to 11.5
hi dear,
i want to upgrade our cucm from 10.5, to 11.5, the scenario is
we install new cucm 11.5 , so we will have 2 cucm different version running in different server and IP.
and we will install it with PCD.
the question is, how the new cucm get all settings in old cucm?
please help
thanks
PCD will do that automatically when you use the migrate option, it will restore the complete configuration of the old CUCM in the new one.
Rajan
7 Replies 7
Rajan
Hi Alpert,
In PCD, follow the migration procedure to migrate the old CUCM to the server where you want the new one. During this process PCD will export and import all the configuration to the new one and you also have an option to change the IP address. Once this is up and running, you can initiate upgrade of the migrated CUCM (new one) to 11.5.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/pcdadmin/11_0_1/CUCM_BK_PB6D9005_00_pcd-administration-guide-110/cisco_prime_collaboration_deployment_features.html
You need to point all the endpoints to the corresponding CUCM IPs for them to register as per the requirement.
Rajan
Pls rate all useful posts
hai Raj,
thanks for the replied,
let me explain again, so, i will upgrade my cucm, but the way is, i ll install new one cucm 11.5, and import all user in cucm 10.5 building by building, or one by one, i dont want upgrade the old cucm, in other words i want to use or install cucm 11.5 but the settings use the old CUCM.
please let me know if you get the point.
thanks
Hi Alpert,
I guess you want to keep the old cucm in 10.5 version and a new one 11.5 version with all the settings from 10.5. Right ?
For exporting and importing data, the version needs to be same. Hence you can migrate the existing 10.5 CUCM to a new server where it will also get all the settings & configurations from the existing server. Then upgrade only the new one to 11.5. the old one will remain in 10.5 version.
Rajan
Pls rate all useful posts by clicking the star below
hi raj,
right,
can i restore all backup data from old to the new one?
or there are no other way to get data from old to import to new cucm?
or i must make it all setting manually?
thanks
Rajan
oke thank raj for the answer.
i will follow your suggestion to copy the old to new server and upgrade it use PCD.
Watch this and it will clear things our for you, as it seems you don't understand how a PCD migration works.
You can do all you want in a single step:
https://youtu.be/2C_gy_XmBmE
java
if this helps, please rate
