Use browser to view 7941 display
amiguel123
i know there is a url that you can use to view a deskphone display. i know about browsing a phone and seeing all the configurations but i want to view the deskphone display.
URL....IP address/somthing
Anyone know that one?
Andy
Check authentication url parameter on CUCM (DNS dependency).
Rate helpful posts.
Thks
met
metalium2007
Level 3
Level 3
Hello my friend,
So you can do it this way:
- make the ipphone controlled by a user in the user page;
- make that user member of the group Standard CCM Phone Administration;
Go to:
http:///CGI/Screenshot     (case sensitive)
Then you will be asked to enter username and password. Use the user/password combination you configured on first steps.
Image will appear on browser
Hope this helps!
met
Thank you for the help. i get this message when i use that URL format
<CiscoIPPhoneError Number="4" />
Any ideas?
Andy
Rate helpful posts.
Thks
met
Thank you. Looks like i have a deeper problem. We use clicktodial and i think
the authinticaion server is not up to par at this time.
