User chosen MOH
bejoy.cisco
Is it possible to have User chosen MOH with any version of CUCM. The requirement is to have a caller dial in to the PBX and when put on hold, the caller is prompted with an IVR asking him to choose what kind of music he will be interested in listening to.
If not possible with CUCM alone, can you please recommend me a solution which will support the feature.
Bejoy Thomas
Jaime Valencia
No, CUCM is not an IVR so there's no way to have this on CUCM and the MOH is selected by the device which puts you on hold and that's not a dynamic config.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
