VLAN issues and IP phone issues. Need some help.
bkepley93
1. I am unable to get the network on one VLAN to ping another VLAN network. Also, VLANs are unable to get a proper IP address or connect to the internet. The only VLAN that can get internet or network connection is VLAN 25. I can ping the vlan gateways from the switches.
2. I am trying to have the Cisco WAP571 to use the VLANs also to separate traffic to the proper VLAN.
3. IP Phone 7960 is not getting a proper IP address for firmware it's getting a 10.25.0.x IP address instead of 10.10.35.x
4. IP Phone 7945G is not installing the firmware. It has an address of 10.10.35.x with term45.default but not installing the firmware
5. Even though my switch is POE+ the Cisco WAP571 still complains about needing to be basically a POE+ switch especially when using both ethernet ports on the Cisco WAP571. When using both ports on Cisco WAP571 Eth0/PD is active but Eth1 is not. The ports that the Cisco WAP571 are connected to are set as a trunk due to all of the VLANs needing to be able to accessed with using wireless. I do have power inline static set to max on both ports with the same issue
Router config
Building configuration...
Current configuration : 14954 bytes
! Last configuration change at 21:17:41 CST Tue Dec 8 2020
version 15.1
hostname C3825Router
boot-start-marker
warm-reboot
boot-end-marker
no aaa new-model
clock timezone CST -6 0
clock summer-time CDT recurring
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.10.25.1 10.10.25.25
ip dhcp excluded-address 10.10.35.1 10.10.35.35
ip dhcp excluded-address 10.10.45.1 10.10.45.45
ip dhcp excluded-address 10.10.55.1 10.10.55.55
ip dhcp excluded-address 10.10.99.1 10.10.99.99
ip dhcp pool Data
network 10.10.25.0 255.255.255.0
default-router 10.10.25.1
dns-server 75.75.75.75 75.75.76.76 1.1.1.1 1.0.0.1
ip dhcp pool Voice
network 10.10.35.0 255.255.255.0
default-router 10.10.35.1
option 150 ip 10.10.25.85
option 66 ip 10.10.25.85
ip dhcp pool static
ip dhcp pool host2
ip dhcp pool Security
network 10.10.45.0 255.255.255.0
default-router 10.10.45.1
ip dhcp pool Guest
network 10.10.55.0 255.255.255.0
default-router 10.10.55.1
ip dhcp pool Management
network 10.10.99.0 255.255.255.0
default-router 10.10.99.1
ip name-server 1.1.1.1
ip name-server 1.0.0.1
no ipv6 cef
voice-card 0
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
registrar server expires max 3600 min 120
voice register global
mode cme
source-address 10.10.35.9 port 5060
max-dn 40
max-pool 42
load 7960-7940 P0S3-07-4-00
tftp-path flash:
file text
create profile sync 0000840745363412
voice register dn 1
number 2001
allow watch
name PH-2001
label 2001
mwi
voice register dn 2
number 2002
allow watch
name PH-2002
label 2002
mwi
voice register dn 3
number 2003
allow watch
name PH-2003
label 2003
mwi
voice register dn 4
number 2004
allow watch
name PH-2004
label 2004
mwi
voice register dn 5
number 2005
allow watch
name PH-2005
label 2005
mwi
voice register dn 6
number 2006
allow watch
name PH-2006
label 2006
mwi
voice register dn 7
number 2007
allow watch
name PH-2007
label 2007
mwi
voice register dn 8
number 2008
allow watch
name PH-2008
label 2008
mwi
voice register dn 9
number 2009
allow watch
name PH-2009
label 2009
mwi
voice register dn 10
number 2010
allow watch
name PH-2010
label 2010
mwi
license udi pid CISCO3825 sn FTX0937A3DP
redundancy
ip tftp source-interface GigabitEthernet0/1.25
interface GigabitEthernet0/0
description WAN
ip address dhcp
ip nat outside
ip virtual-reassembly in max-fragments 64 max-reassemblies 1024 timeout 5
ip virtual-reassembly out max-fragments 64 max-reassemblies 1024 timeout 5
duplex auto
speed auto
media-type rj45
description LAN
no ip address
ip nat inside
duplex auto
speed auto
media-type rj45
description LAN-Data
encapsulation dot1Q 25 native
ip address 10.10.25.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.35
description LAN-Voice
encapsulation dot1Q 35
ip address 10.10.35.1 255.255.255.0
ip helper-address 10.10.35.1
ip nat inside
interface GigabitEthernet0/1.45
description LAN-Security
encapsulation dot1Q 45
ip address 10.10.45.1 255.255.255.0
ip helper-address 10.10.45.1
ip nat inside
interface GigabitEthernet0/1.55
description LAN-Guest
encapsulation dot1Q 55
ip address 10.10.55.1 255.255.255.0
ip helper-address 10.10.55.1
ip nat inside
interface GigabitEthernet0/1.99
description Management
encapsulation dot1Q 99
ip address 10.10.99.1 255.255.255.0
ip helper-address 10.10.99.1
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 10.10.25.85 3389 interface GigabitEthernet0/0 3389
ip nat inside source static tcp 10.10.25.71 3390 interface GigabitEthernet0/0 3390
ip nat inside source static tcp 10.10.25.85 32400 interface GigabitEthernet0/0 32404
ip nat inside source static tcp 10.10.25.85 32401 interface GigabitEthernet0/0 32401
ip nat inside source static udp 10.10.25.85 5001 interface GigabitEthernet0/0 5001
ip nat inside source static tcp 10.10.25.85 5001 interface GigabitEthernet0/0 5001
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
logging esm config
access-list 1 permit 10.10.25.0 0.0.0.255
access-list 1 permit 10.10.35.0 0.0.0.255
access-list 1 permit 10.10.45.0 0.0.0.255
access-list 1 permit 10.10.55.0 0.0.0.255
access-list 1 permit 10.10.99.0 0.0.0.255
access-list 101 permit ip 10.10.0.0 0.0.255.255 any
access-list 101 permit ip 10.10.0.0 0.0.0.255 any
access-list 101 permit ip 10.10.25.0 0.0.0.255 any
access-list 101 permit ip 10.10.35.0 0.0.0.255 any
access-list 101 permit ip 10.10.45.0 0.0.0.255 any
access-list 101 permit ip 10.10.55.0 0.0.0.255 any
access-list 101 permit ip 10.10.99.0 0.0.0.255 any
tftp-server flash:Desktops/320x212x12/CampusNight.png
tftp-server flash:Desktops/320x212x12/CiscoFountain.png
tftp-server flash:Desktops/320x212x12/CiscoLogo.png
tftp-server flash:Desktops/320x212x12/FOUNTAIN.PNG
tftp-server flash:Desktops/320x212x12/LIST.XML
tftp-server flash:Desktops/320x212x12/MorroRock.png
tftp-server flash:Desktops/320x212x12/NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/Thumbs.db
tftp-server flash:Desktops/320x212x12/TN-CampusNight.png
tftp-server flash:Desktops/320x212x12/TN-CiscoFountain.png
tftp-server flash:Desktops/320x212x12/TN-CiscoLogo.png
tftp-server flash:Desktops/320x212x12/TN-Fountain.png
tftp-server flash:Desktops/320x212x12/TN-MorroRock.png
tftp-server flash:Desktops/320x212x12/TN-NantucketFlowers.png
tftp-server flash:CME8_6/Ringtones/Analog1.raw
tftp-server flash:CME8_6/Ringtones/Analog2.raw
tftp-server flash:CME8_6/Ringtones/AreYouThere.raw
tftp-server flash:CME8_6/Ringtones/AreYouThereF.raw
tftp-server flash:CME8_6/Ringtones/Bass.raw
tftp-server flash:CME8_6/Ringtones/CallBack.raw
tftp-server flash:CME8_6/Ringtones/Chime.raw
tftp-server flash:CME8_6/Ringtones/Classic1.raw
tftp-server flash:CME8_6/Ringtones/Classic2.raw
tftp-server flash:CME8_6/Ringtones/ClockShop.raw
tftp-server flash:CME8_6/Ringtones/DistinctiveRingList.xml
tftp-server flash:CME8_6/Ringtones/Drums1.raw
tftp-server flash:CME8_6/Ringtones/Drums2.raw
tftp-server flash:CME8_6/Ringtones/FilmScore.raw
tftp-server flash:CME8_6/Ringtones/HarpSynth.raw
tftp-server flash:CME8_6/Ringtones/Jamaica.raw
tftp-server flash:CME8_6/Ringtones/KotoEffect.raw
tftp-server flash:CME8_6/Ringtones/MusicBox.raw
tftp-server flash:CME8_6/Ringtones/Piano1.raw
tftp-server flash:CME8_6/Ringtones/Piano2.raw
tftp-server flash:CME8_6/Ringtones/Pop.raw
tftp-server flash:CME8_6/Ringtones/Pulse1.raw
tftp-server flash:CME8_6/Ringtones/Ring1.raw
tftp-server flash:CME8_6/Ringtones/Ring2.raw
tftp-server flash:CME8_6/Ringtones/Ring3.raw
tftp-server flash:CME8_6/Ringtones/Ring4.raw
tftp-server flash:CME8_6/Ringtones/Ring5.raw
tftp-server flash:CME8_6/Ringtones/Ring6.raw
tftp-server flash:CME8_6/Ringtones/Ring7.raw
tftp-server flash:CME8_6/Ringtones/Ringlist.xml
tftp-server flash:CME8_6/Ringtones/Sax1.raw
tftp-server flash:CME8_6/Ringtones/Sax2.raw
tftp-server flash:CME8_6/Ringtones/Vibe.raw
tftp-server flash:/DIALPLAN.XML
tftp-server flash:music-on-hold.au
tftp-server flash:P003-07-5-00.sbn
tftp-server flash:P0S3-07-5-00.bin
tftp-server flash:P0S3-07-5-00.loads
tftp-server flash:P0S3-07-5-00.sb2
tftp-server flash:P003-07-5-00.bin
tftp-server flash:P00308010200.bin
tftp-server flash:P00308010200.loads
tftp-server flash:P00308010200.sb2
tftp-server flash:P00308010200.sbn
tftp-server flash:cmterm-7940-7960-sccp.8-1-2.cop
tftp-server flash:cmterm-7940-7960-sccp.8-1-2.cop.sgn
tftp-server flash:cmterm-7940-7960-sccp.8-1-2.exe
tftp-server flash:cmterm-7940-7960-sccp.8-1-2.zip
tftp-server flash:SCCP-Phones/7942G-7962G/cmterm-7942_7962-sccp.9-3-1SR4-1/7942-7962.tar
tftp-server flash:SCCP-Phones/7942G-7962G/cmterm-7942_7962-sccp.9-3-1SR4-1/apps42.9-3-1ES26.sbn
tftp-server flash:SCCP-Phones/7942G-7962G/cmterm-7942_7962-sccp.9-3-1SR4-1/cnu42.9-3-1ES26.sbn
tftp-server flash:SCCP-Phones/7942G-7962G/cmterm-7942_7962-sccp.9-3-1SR4-1/cvm42sccp.9-3-1ES26.sbn
tftp-server flash:SCCP-Phones/7942G-7962G/cmterm-7942_7962-sccp.9-3-1SR4-1/dsp42.9-3-1ES26.sbn
tftp-server flash:SCCP-Phones/7942G-7962G/cmterm-7942_7962-sccp.9-3-1SR4-1/jar42sccp.9-3-1ES26.sbn
tftp-server flash:SCCP-PhG-1S.loads
tftp-server flash:SCCP-Phones/7945G-7965G/cmterm-7945_7965-sccp.9-3-1SR4-1/term45.default.loads
tftp-server flash:CME8_6/SCCP42.8-_6/term06.default.loads
tftp-server flash:CME8_6/term11.default.loads
tftp-server flash:CME8_6/term31.default.loads
tftp-server flash:CME8_6/term41.default.loads
tftp-server flash:P00307020300.loads
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp profile default
sip-ua
credentials number 13098635246 username GV13098635246 password 7 08764E5A5F03242137005E3D2227 realm GVGW
authentication username GV13098635246 password 7 073529187A031A5D433A331D35
registrar dns:gvgw3.simonics.com:5070 expires 1800 tcp
sip-server dns:gvgw3.simonics.com:5070
telephony-service
moh-file-buffer 2000
max-ephones 30
max-dn 50
ip source-address 10.10.35.2 port 2000
ip qos dscp af31 signal
service dnis overlay
service dnis dir-lookup
timeouts interdigit 2
system message Ciscoland.net
cnf-file location flash:
load 7960-7940 P00307020300
load 7941 SCCP41.9-3-1SR4-1S
load 7942 SCCP42.9-3-1SR4-1S
load 7945 SCCP45.9-2-1S
load 7961 SCCP41.9-3-1SR4-1S
load 7962 SCCP42.9-3-1SR4-1S
load 7965 SCCP45.9-3-1SR4-1S
dialplan-pattern 1 5... extension-length 4
max-conferences 4 gain -6
moh music-on-hold.au
multicast moh 239.1.1.1 port 2000 route 10.10.25.1 10.10.35.1
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
directory entry 1 2580 name Human Resources
directory entry 2 2648 name IT Help Desk
directory entry 3 2860 name Security
directory entry 4 4286 name Front Desk
directory entry 5 8620 name Grounds Maintence
directory entry 6 8684 name Confrence Room
directory entry 7 2448 name Break Roon
directory entry 8 2864 name Building Maintence
directory entry 9 4884 name Computer Room
directory entry 10 8684 name Living Room
directory entry 11 2448 name Kitchen
directory entry 12 2864 name Bedroom 2 - Brandon
directory entry 13 8888 name Server/Networking Room
directory entry 14 8666 name DJ Laptop
create cnf-files version-stamp 7960 Jan 24 2019 07:02:49
ephone-dn 1 dual-line
number 2580
label 2580
description Human Resources
hold-alert 30 originator
ephone-dn 2 dual-line
number 2648
label 2648
description IT Help Desk
name IT Help Desk
ephone-dn 3 dual-line
number 2860
label 2860
description Security
name Security
ephone-dn 4 dual-line
number 4286
label 4286
description Front Desk
name Front Desk
ephone-dn 5 dual-line
number 4884
label 4884
description Computer Room
name Computer Room
ephone-dn 6 dual-line
number 8684
label 8684
description Living Room
name Living Room
ephone-dn 7 dual-line
number 2448
label 2448
description Kitchen
name Kitchen
ephone-dn 8 dual-line
number 2864
label 2864
description Bedroom 2 - Brandon
ephone-dn 9 dual-line
number 8888
label 8888
description Server/Networking Room
name Phone Server/Networking Room
ephone-dn 12 dual-line
number 8666
label DJ Laptop
name DJ Laptop
ephone 1
device-security-mode none
mac-address 000B.BEAD.4D4F
type 7960
button 1:1
ephone 2
mac-address 0011.92BA.230B
speed-dial 1 2860 label "Security"
speed-dial 2 2580 label "Human Resources"
speed-dial 3 4286 label "Front Desk"
speed-dial 4 1010 label "Lab"
type 7960
button 1:2
ephone 3
mac-address 000F.8FC6.9EE8
type 7960
button 1:3
ephone 4
mac-address 000B.BEAD.42CF
type 7960
button 1:4
ephone 5
mac-address C062.6BD3.2E41
type 7945
button 1:5
ephone 6
mac-address 0023.339B.F76B
type 7945
button 1:6
ephone 7
mac-address 0021.A02C.A957
type 7945
button 1:7
ephone 8
mac-address 0021.A02C.C59C
type 7945
button 1:8
ephone 9
mac-address 34BD.C82D.4CDB
type 7945
button 1:9
ephone 10
ephone 11
ephone 12
mac-address F01F.AF46.3036
type CIPC
button 1:12
ephone 13
ephone 15
ephone 17
ephone 18
alias exec con conf t
alias exec sib show ip int brief
alias exec srb show run | b
alias exec sri show run int
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
privilege level 15
login
transport input telnet ssh
transport output telnet ssh
line vty 5 15
privilege level 15
login
scheduler allocate 20000 1000
end
Switch
Current configuration : 11371 bytes
! Last configuration change at 14:52:40 UTC Mon Jan 2 2006
version 15.2
no service pad
hostname C3560X-48poeSwitch1
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
crypto pki trustpoint TP-self-signed-4138183552
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4138183552
revocation-check none
rsakeypair TP-self-signed-4138183552
crypto pki certificate chain TP-self-signed-4138183552
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 34313338 31383335 3532301E 170D3036 30313032 30313432
34335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 31333831
38333535 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100A2DA A4D768C0 E817C400 AFC7C81A 6D4A7BB8 750AF0DC 01BAD416 5D4A9246
12D4B605 1B9AEB52 195BB5DF E78A92E9 F21B7FC6 147379AD B23FFC6C BCC9219E
2ABCF6DF D9957EE9 D9EF503B 31945CE0 173E9F16 0B9C3820 77A1FEE8 D4320223
9CEAB5C8 9405E239 A09BD03F 30F6C3EC 2E427BA3 521F9D36 100A6976 BBBA6EC7
77230203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14C10DBB 6C7F6639 172C3AB1 F23740ED 330846DD 41301D06
03551D0E 04160414 C10DBB6C 7F663917 2C3AB1F2 3740ED33 0846DD41 300D0609
2A864886 F70D0101 05050003 81810069 4ED46A3D 8EDF8B00 39DE38F5 A9F99D14
DC01956C F0072E66 105312FF 593783E1 4E5E65D2 B7D34763 7780F147 2AFFD9A4
A2CE2392 1CBD5C13 05AA5480 166EA2EB 5716EDCA 76D24DA0 E8EF1945 FAEE638B
FBFF99A5 7A3C3A68 9F54DA7A D237C6D2 E87F41FB FD0D41D1 BCD4BAAA 36E29611
5A33EC4F ABBCEB4B A6817196 3A5E7B
quit
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
interface Port-channel1
interface FastEthernet0
no ip address
description Trunk Link From C3825Router
switchport trunk allowed vlan 25-99
switchport trunk native vlan 25
switchport mode trunk
switchport nonegotiate
switchport voice vlan 35
spanning-tree portfast edge
interface GigabitEthernet0/2
description Trunk Link To WLAN CiscoWAP571
power inline static
interface GigabitEthernet0/3
power inline static
interface GigabitEthernet0/4
interface GigabitEthernet0/5
switchport access vlan 25
switchport mode access
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
interface GigabitEthernet0/46
interface GigabitEthernet0/47
description Trunk To C3560X-48poeSwitch2
interface GigabitEthernet0/48
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface Vlan1
no ip address
shutdown
interface Vlan25
ip address 10.10.25.2 255.255.255.0
interface Vlan35
ip address 10.10.35.2 255.255.255.0
interface Vlan45
ip address 10.10.45.2 255.255.255.0
interface Vlan55
ip address 10.10.55.2 255.255.255.0
interface Vlan99
no ip address
ip default-gateway 10.10.25.1
ip http server
line con 0
line vty 5 15
end
0 Replies 0
