отмена
Отображаются результаты для
Вместо этого искать
Вы имели в виду:
Просмотры
Полезный материал
Ответы
VM Ports are not getting register !!
anis_cisco
Hi all,
I have CUCM B.E 6.1 ...
Im integrating Unity Connection with CUCM but Voicemail ports are not getting registered with CUCM
The Device Name of VoiceMail Port at CUCM is CiscoUM1-VI1 and the device name prefix in unity connection at port group is CiscoUM1-VI and the display name of port in Unity Connection is CiscoUM1-VI-001 ...
I checked the troubleshooting guide & it mentioned to check the security mode setting !!! I checked & Security mode in CUCM & Unity Connection is Non-Security !!!
can any body suggest ASAP what could be the reason ??
1 ОТВЕТ 1
Justin Brenton
Level 4
Level 4
Hi Anis,
Your unity connection port group name should be CiscoUM1.
You also need to  create a hunt list, hunt pilot number, and line group for voicemail and assign the CiscoUM1 group.  You then need to ensure your voicemail ports/extension are assigned to the Line Group.
Your line group name in CUCM should be "CiscoUM1", Ports names in CUCM should be i.e
CiscoUM1-VI1, CiscoUM1-VI2, CiscoUM1-VI3, etc
CUCM Setup:
Unity Connection Setup:
HTH, Please rate helpful posts
Justin
