VMware Site Recovery Manager and CUCM Publisher
m.batts
Level 4
Level 4
Has anyone actually used srm manager to move a publisher for example.
If I read the docwiki it says its compatible with caveats.The caveats seem to be shutdown the server before san replication and always have a backup before ,(which worries me)
Anyone done or used this?
Hi m.batts,
the 'always have a backup before' is a best practice and the 'shutdown the server before SAN replication' guarantees that there will be no database replication problem or delays, during the SRM process.
Hope this helps.
Hi Marcelo,
Thanks for the reply n,Yep I realise whats needed , what I more interested in have you actually used this?
cheers
Mark
Hi m.batts,
 I used it in a 'lab environment' and it works without any problem ... I didn't have the opportunity to use it in a 'real environment', but as soon as more and more customers are using vCenter and UC in UCS-B, this will become a common practice.
Hope this helps.
