Vocus SIP trunk incoming not working
SathishAnbu4286
Facing issue with Vocus SIP trunk incoming call. Receiving invite but not routing or matching dial peer. Attached the config please do the needful.
Received:
INVITE sip:0380809216@10.224.78.34:5060 SIP/2.0
Via: SIP/2.0/UDP 202.147.134.21:5060;branch=z9hG4bK3nglve00e84ita1er0e0.1
From: <sip:0919739994990@amcomvoice.ipsystems.com.au;user=phone>;tag=SD0defd01-266667079-1580797966377-
To: "380809216 380809216"<sip:0380809216@amcomvoice.ipsystems.com.au>
Call-ID: SD0defd01-d5c3a28df4d9048c86c0153af2f2d89a-jm6gpa0030
CSeq: 125000725 INVITE
Contact: <sip:SDl5i79-vp9pm6rhjjonlr5pmpv6hvrkbk0qgvagofge3pvv404m90c42sc0@202.147.134.21:5060;transport=udp>
P-Called-Party-ID: <sip:0380809216@amcomvoice.ipsystems.com.au>
Supported: 100rel,timer
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
Recv-Info: x-broadworks-client-session-info
Accept: application/media_control+xml,application/sdp,multipart/mixed
Min-SE: 90
Session-Expires: 1800;refresher=uas
Max-Forwards: 29
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 270
v=0
o=BroadWorks 5479777217 1 IN IP4 202.147.134.21
s=-
c=IN IP4 202.147.134.21
t=0 0
m=audio 18752 RTP/AVP 8 0 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
a=ptime:20
a=bsoft: 1 image udptl t38
TONY SMITH
Have you run a debug to check dial peer matching "debug voip dialpeer inout"?   I'm wondering if it's not matching the correct inbound dial peer, and therefore not getting translated.
Justinwong19918
How did you fix your problems?
I have the same issue.
