Voice Gateway IOS upgrade for CM 6?
Tommer Catlin
Hello all! Does anyone know if IOS on routers need to be upgraded for CM6?
I have 12.4(3g) loaded right now. Not sure if there is prereq for this or not.
Thanks!
gogasca
Level 10
Level 10
I dont think its necessary, actually we are working to update CCM compatibility matrix.
Thanks much. Can you post that link here if you get the matrix done, or where will be able to find this?
