04-24-2013 07:53 AM - edited 03-16-2019 04:58 PM
Hello
Im running on a Cisco Router 2811
IOS version
C2800NM-SPSERVICESK9-M, Version 15.1(3)T4
i have 1 E1 as QSIG connected to a PBX and another E1 to the PSTN
#Show Version
Cisco 2811 (revision 53.51) with 507904K/16384K bytes of memory.
Processor board ID FTX1508AHZH
2 FastEthernet interfaces
30 Serial interfaces
3 Channelized E1/PRI ports
4 Voice FXO interfaces
4 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
126976K bytes of ATA CompactFlash (Read/Write)
I'm constantly presenting the following logs:
Router#show log
Sub Called(TON=Subscriber, NPI=Unknown, Data=^^^XIM>^T, Length=24)
Sub Calling(TON=Subscriber, NPI=Unknown, Data=<\, Length=73)
Sub Called(TON=Subscriber, NPI=Unknown, Data=^^^XIM>^T, Length=36)
Sub Called(TON=Subscriber, NPI=Unknown, Data=^^^XIM>^T, Length=148)
Can someone tell me what these logs are?
Thanks in advance
Regards!
04-24-2013 04:59 PM
That's just info on the type of number and numbering plan from your calls, are you having problems with them??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
