01-22-2020 02:29 AM
We have a SIP trunk from 8x8 and there is a voip link to provider..
When we make outbound calls from 8x8 to US number via the Voice gateway the call is failing.. Incoming is working fine.
Please find the below debug message.. Can you please help me fix this..
Jan 22 09:58:32.540: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname i bucket 16 c_hname Call-ID bucket 14 Jan 22 09:58:32.540: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname f bucket 13 c_hname From bucket 4 Jan 22 09:58:32.540: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname t bucket 8 c_hname To bucket 11 Jan 22 09:58:32.540: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname l bucket 0 c_hname Content-Length bucket 8 Jan 22 09:58:32.540: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname v bucket 10 c_hname Via bucket 15 Jan 22 09:58:32.540: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ACK sip:911669228XXXX@182.75.YY.XXX:5060;user=phone SIP/2.0 i: bMh2G6iLd5Hd f: "SIP TEST" <sip:142442XXXX4@8.20.XX.YY:6055>;tag=bUhFAeO2PZA9K t: <sip:911669228XXXX@8.28.0.71:8115>;tag=423A8120-E62 CSeq: 1286567370 ACK Max-Forwards: 70 User-Agent: eSLEE/0.13.98.6 l: 0 v: SIP/2.0/UDP 8.28.0.71:8115;branch=z9hG4bKaqWF5Lq6BhAd Jan 22 09:58:32.544: //3543923/6F15278C9A23/CCAPI/cc_api_call_disconnect_done: Disposition=0, Interface=0x13684C28, Tag=0x0, Call Id=3543923, Call Entry(Disconnect Cause=102, Voice Class Cause Code=0, Retry Count=0) Jan 22 09:58:32.544: //3543923/6F15278C9A23/CCAPI/cc_api_call_disconnect_done: Call Disconnect Event Sent Jan 22 09:58:32.544: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa: Jan 22 09:58:32.544: :cc_free_feature_vsa freeing 1256E350 Jan 22 09:58:32.544: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa: Jan 22 09:58:32.544: vsacount in free is 0 Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname f bucket 13 c_hname From bucket 4 Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname i bucket 16 c_hname Call-ID bucket 14 Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname t bucket 8 c_hname To bucket 11 Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname k bucket 18 c_hname Supported bucket 7 Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname l bucket 0 c_hname Content-Length bucket 8 Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname c bucket 10 c_hname Content-Type bucket 13 Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname x bucket 12 c_hname Session-Expires bucket 16 Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname m bucket 1 c_hname Contact bucket 11 Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname v bucket 10 c_hname Via bucket 15 Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: INVITE sip:911669228XXXX@182.75.YY.XXX:5060;user=phone SIP/2.0 CSeq: 1286749321 INVITE f: "SIP TEST" <sip:142442XXXX4@8.20.XX.YY:6055>;tag=bF1uQiuSRLMcK i: bUMBus4xMTUj t: <sip:911669228XXXX@8.28.0.71:8115> Max-Forwards: 70 k: timer, histinfo l: 318 Remote-Party-ID: "SIP TEST" <sip:142442XXXX4@8.20.XX.YY:6055>;party=calling;privacy=off User-Agent: Packet8/1.2.134.11 (outaryaka248) eSLEE/0.13.98.6 c: application/sdp x: 1893 m: <sip:bH3fKmtdFUq5gVDhUId@8.28.0.71:8115> v: SIP/2.0/UDP 8.28.0.71:8115;branch=z9hG4bKaPjvpZq2iyf v=0 o=VOC-Mac 0 0 IN IP4 172.17.16.72 s=- c=IN IP4 117.20.40.200 t=0 0 m=audio 31682 RTP/AVP 110 102 0 8 101 a=rtpmap:110 opus/48000/2 a=fmtp:110 maxplaybackrate=16000;sprop-maxcapturerate=16000;maxaveragebitrate=20000 a=rtpmap:102 iLBC/8000 a=fmtp:102 mode=20 a=rtpmap:101 telephone-event/8000 a=ptime:20 SIP: (3543925) Attribute mid, level 1 instance 1 not found. Jan 22 10:00:30.737: //3543925/DB88F73E9A2A/SIP/Error/sipSPI_ipip_copy_sdp_to_channelInfo: failed to update call entry Jan 22 10:00:30.737: //3543925/DB88F73E9A2A/SIP/Error/sipSPI_ipip_copy_sdp_to_channelInfo: failed to update call entry Jan 22 10:00:30.737: //3543925/DB88F73E9A2A/SIP/Error/sipSPI_ipip_copy_sdp_to_channelInfo: Unable to find the proper instance for FMTP SIP: (3543925) fmtp attribute, level 1 instance 0 not found. Jan 22 10:00:30.737: //3543925/DB88F73E9A2A/SIP/Error/sipSPI_ipip_copy_sdp_to_channelInfo: Unable to acquire event mask for rfc2833 dtmf relay Jan 22 10:00:30.737: //3543925/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind: Call Entry Is Not Found Jan 22 10:00:30.737: //-1/DB88F73E9A2A/CCAPI/cc_api_display_ie_subfields: cc_api_call_setup_ind_common: cisco-username=142442XXXX4 ----- ccCallInfo IE subfields ----- cisco-ani=142442XXXX4 cisco-anitype=0 cisco-aniplan=0 cisco-anipi=0 cisco-anisi=0 dest=911669228XXXX cisco-desttype=0 cisco-destplan=0 cisco-rdie=FFFFFFFF cisco-rdn= cisco-lastrdn= cisco-rdntype=0 cisco-rdnplan=0 cisco-rdnpi=-1 cisco-rdnsi=-1 cisco-redirectreason=-1 fwd_final_type =0 final_redirectNumber = hunt_group_timeout =0 Jan 22 10:00:30.737: //-1/DB88F73E9A2A/CCAPI/cc_api_call_setup_ind_common: Interface=0x13684C28, Call Info( Calling Number=142442XXXX4,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed), Called Number=911669228XXXX(TON=Unknown, NPI=Unknown), Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE, Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=3543925 Jan 22 10:00:30.737: //-1/DB88F73E9A2A/CCAPI/ccCheckClipClir: In: Calling Number=142442XXXX4(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed) Jan 22 10:00:30.737: //-1/DB88F73E9A2A/CCAPI/ccCheckClipClir: Out: Calling Number=142442XXXX4(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed) Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: Jan 22 10:00:30.737: :cc_get_feature_vsa malloc success Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: Jan 22 10:00:30.737: cc_get_feature_vsa count is 1 Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: Jan 22 10:00:30.737: :FEATURE_VSA attributes are: feature_name:0,feature_time:373291416,feature_id:2380043 Jan 22 10:00:30.737: //3543925/DB88F73E9A2A/CCAPI/cc_api_call_setup_ind_common: Set Up Event Sent; Call Info(Calling Number=142442XXXX4(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed), Called Number=911669228XXXX(TON=Unknown, NPI=Unknown)) Jan 22 10:00:30.737: //3543925/DB88F73E9A2A/CCAPI/cc_process_call_setup_ind: Event=0x1E72738 Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search: Try with the demoted called number 911669228XXXX Jan 22 10:00:30.737: //3543925/DB88F73E9A2A/CCAPI/ccCallSetContext: Context=0x16AD9DC0 Jan 22 10:00:30.737: //3543925/DB88F73E9A2A/CCAPI/cc_process_call_setup_ind: >>>>CCAPI handed cid 3543925 with tag 1 to app "_ManagedAppProcess_Default" Jan 22 10:00:30.737: //3543925/DB88F73E9A2A/CCAPI/ccCallProceeding: Progress Indication=NULL(0) Jan 22 10:00:30.741: //3543925/DB88F73E9A2A/CCAPI/ccCallSetupRequest: Destination=, Calling IE Present=TRUE, Mode=0, Outgoing Dial-peer=91, Params=0x2E88A5C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3) Jan 22 10:00:30.741: //3543925/DB88F73E9A2A/CCAPI/ccCheckClipClir: In: Calling Number=142442XXXX4(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed) Jan 22 10:00:30.741: //3543925/DB88F73E9A2A/CCAPI/ccCheckClipClir: Out: Calling Number=142442XXXX4(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed) Jan 22 10:00:30.741: //3543925/DB88F73E9A2A/CCAPI/ccCallSetupRequest: Destination Pattern=91T, Called Number=001669228XXXX, Digit Strip=FALSE Jan 22 10:00:30.741: //3543925/DB88F73E9A2A/CCAPI/ccCallSetupRequest: Calling Number=142442XXXX4(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed), Called Number=001669228XXXX(TON=Unknown, NPI=Unknown), Redirect Number=, Display Info=SIP TEST Account Number=142442XXXX4, Final Destination Flag=TRUE, Guid=DB88F73E-3C34-11EA-9A2A-B8E4830712E5, Outgoing Dial-peer=91 Jan 22 10:00:30.741: //3543925/DB88F73E9A2A/CCAPI/cc_api_display_ie_subfields: ccCallSetupRequest: cisco-username=142442XXXX4 ----- ccCallInfo IE subfields ----- cisco-ani=142442XXXX4 cisco-anitype=0 cisco-aniplan=0 cisco-anipi=0 cisco-anisi=0 dest=001669228XXXX cisco-desttype=0 cisco-destplan=0 cisco-rdie=FFFFFFFF cisco-rdn= cisco-lastrdn= cisco-rdntype=0 cisco-rdnplan=0 cisco-rdnpi=-1 cisco-rdnsi=-1 cisco-redirectreason=-1 fwd_final_type =0 final_redirectNumber = hunt_group_timeout =0 Jan 22 10:00:30.741: //3543925/DB88F73E9A2A/CCAPI/ccIFCallSetupRequestPrivate: Interface=0x13684C28, Interface Type=3, Destination=, Mode=0x0, Call Params(Calling Number=142442XXXX4,(Calling Name=SIP TEST)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed), Called Number=001669228XXXX(TON=Unknown, NPI=Unknown), Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=91, Call Count On=FALSE, Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=) Jan 22 10:00:30.741: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: Jan 22 10:00:30.741: :cc_get_feature_vsa malloc success Jan 22 10:00:30.741: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: Jan 22 10:00:30.741: cc_get_feature_vsa count is 2 Jan 22 10:00:30.741: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: Jan 22 10:00:30.741: :FEATURE_VSA attributes are: feature_name:0,feature_time:373291192,feature_id:2380044 Jan 22 10:00:30.741: //3543926/DB88F73E9A2A/CCAPI/ccIFCallSetupRequestPrivate: SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1 Jan 22 10:00:30.741: //3543926/DB88F73E9A2A/CCAPI/ccCallSetContext: Context=0x2E88A0C Jan 22 10:00:30.741: //3543925/DB88F73E9A2A/CCAPI/ccSaveDialpeerTag: Outgoing Dial-peer=91 Jan 22 10:00:30.741: //3543926/DB88F73E9A2A/CCAPI/cc_api_call_proceeding: Interface=0x13684C28, Progress Indication=NULL(0) SIP: (3543926) Group (a= group line) attribute, level 65535 instance 1 not found. Jan 22 10:00:30.741: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 100 Trying Via: SIP/2.0/UDP 8.28.0.71:8115;branch=z9hG4bKaPjvpZq2iyf From: "SIP TEST" <sip:142442XXXX4@8.20.XX.YY:6055>;tag=bF1uQiuSRLMcK To: <sip:911669228XXXX@8.28.0.71:8115> Date: Wed, 22 Jan 2020 10:00:30 GMT Call-ID: bUMBus4xMTUj CSeq: 1286749321 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-12.x Content-Length: 0 Jan 22 10:00:30.741: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:001669228XXXX@121.244.230.10:5060 SIP/2.0 Via: SIP/2.0/UDP 10.196.236.238:5060;branch=z9hG4bK266A7D162 Remote-Party-ID: "SIP TEST" <sip:142442XXXX4@10.196.236.238>;party=calling;screen=no;privacy=off From: "SIP TEST" <sip:142442XXXX4@10.196.236.238>;tag=423C4FD0-270B To: <sip:001669228XXXX@121.244.230.10> Date: Wed, 22 Jan 2020 10:00:30 GMT Call-ID: DB899366-3C3411EA-9A30B8E4-830712E5@10.196.236.238 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 3683186494-1010045418-2586491108-2198278885 User-Agent: Cisco-SIPGateway/IOS-12.x Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 101 INVITE Timestamp: 1579687230 Contact: <sip:142442XXXX4@10.196.236.238:5060> Expires: 180 Allow-Events: telephone-event Max-Forwards: 69 Session-Expires: 1893 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 302 v=0 o=CiscoSystemsSIP-GW-UserAgent 6755 2217 IN IP4 10.196.236.238 s=SIP Call c=IN IP4 10.196.236.238 t=0 0 m=audio 28062 RTP/AVP 0 100 101 c=IN IP4 10.196.236.238 a=rtpmap:0 PCMU/8000 a=rtpmap:100 X-NSE/8000 a=fmtp:100 192-194 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=ptime:20 SIP: (3543926) Group (a= group line) attribute, level 65535 instance 1 not found. Jan 22 10:00:31.241: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:001669228XXXX@121.244.230.10:5060 SIP/2.0 Via: SIP/2.0/UDP 10.196.236.238:5060;branch=z9hG4bK266A7D162 Remote-Party-ID: "SIP TEST" <sip:142442XXXX4@10.196.236.238>;party=calling;screen=no;privacy=off From: "SIP TEST" <sip:142442XXXX4@10.196.236.238>;tag=423C4FD0-270B To: <sip:001669228XXXX@121.244.230.10> Date: Wed, 22 Jan 2020 10:00:31 GMT Call-ID: DB899366-3C3411EA-9A30B8E4-830712E5@10.196.236.238 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 3683186494-1010045418-2586491108-2198278885 User-Agent: Cisco-SIPGateway/IOS-12.x Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 101 INVITE Timestamp: 1579687231 Contact: <sip:142442XXXX4@10.196.236.238:5060> Expires: 180 Allow-Events: telephone-event Max-Forwards: 69 Session-Expires: 1893 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 302 v=0 o=CiscoSystemsSIP-GW-UserAgent 6755 2217 IN IP4 10.196.236.238 s=SIP Call c=IN IP4 10.196.236.238 t=0 0 m=audio 28062 RTP/AVP 0 100 101 c=IN IP4 10.196.236.238 a=rtpmap:0 PCMU/8000 a=rtpmap:100 X-NSE/8000 a=fmtp:100 192-194 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=ptime:20 SIP: (3543926) Group (a= group line) attribute, level 65535 instance 1 not found. Jan 22 10:00:32.241: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:001669228XXXX@121.244.230.10:5060 SIP/2.0 Via: SIP/2.0/UDP 10.196.236.238:5060;branch=z9hG4bK266A7D162 Remote-Party-ID: "SIP TEST" <sip:142442XXXX4@10.196.236.238>;party=calling;screen=no;privacy=off From: "SIP TEST" <sip:142442XXXX4@10.196.236.238>;tag=423C4FD0-270B To: <sip:001669228XXXX@121.244.230.10> Date: Wed, 22 Jan 2020 10:00:32 GMT Call-ID: DB899366-3C3411EA-9A30B8E4-830712E5@10.196.236.238 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 3683186494-1010045418-2586491108-2198278885 User-Agent: Cisco-SIPGateway/IOS-12.x Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 101 INVITE Timestamp: 1579687232 Contact: <sip:142442XXXX4@10.196.236.238:5060> Expires: 180 Allow-Events: telephone-event Max-Forwards: 69 Session-Expires: 1893 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 302 v=0 o=CiscoSystemsSIP-GW-UserAgent 6755 2217 IN IP4 10.196.236.238 s=SIP Call c=IN IP4 10.196.236.238 t=0 0 m=audio 28062 RTP/AVP 0 100 101 c=IN IP4 10.196.236.238 a=rtpmap:0 PCMU/8000 a=rtpmap:100 X-NSE/8000 a=fmtp:100 192-194 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=ptime:20 SIP: (3543926) Group (a= group line) attribute, level 65535 instance 1 not found. Jan 22 10:00:34.241: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:001669228XXXX@121.244.230.10:5060 SIP/2.0 Via: SIP/2.0/UDP 10.196.236.238:5060;branch=z9hG4bK266A7D162 Remote-Party-ID: "SIP TEST" <sip:142442XXXX4@10.196.236.238>;party=calling;screen=no;privacy=off From: "SIP TEST" <sip:142442XXXX4@10.196.236.238>;tag=423C4FD0-270B To: <sip:001669228XXXX@121.244.230.10> Date: Wed, 22 Jan 2020 10:00:34 GMT Call-ID: DB899366-3C3411EA-9A30B8E4-830712E5@10.196.236.238 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 3683186494-1010045418-2586491108-2198278885 User-Agent: Cisco-SIPGateway/IOS-12.x Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 101 INVITE Timestamp: 1579687234 Contact: <sip:142442XXXX4@10.196.236.238:5060> Expires: 180 Allow-Events: telephone-event Max-Forwards: 69 Session-Expires: 1893 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 302 v=0 o=CiscoSystemsSIP-GW-UserAgent 6755 2217 IN IP4 10.196.236.238 s=SIP Call c=IN IP4 10.196.236.238 t=0 0 m=audio 28062 RTP/AVP 0 100 101 c=IN IP4 10.196.236.238 a=rtpmap:0 PCMU/8000 a=rtpmap:100 X-NSE/8000 a=fmtp:100 192-194 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=ptime:20 SIP: (3543926) Group (a= group line) attribute, level 65535 instance 1 not found. Jan 22 10:00:38.241: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:001669228XXXX@121.244.230.10:5060 SIP/2.0 Via: SIP/2.0/UDP 10.196.236.238:5060;branch=z9hG4bK266A7D162 Remote-Party-ID: "SIP TEST" <sip:142442XXXX4@10.196.236.238>;party=calling;screen=no;privacy=off From: "SIP TEST" <sip:142442XXXX4@10.196.236.238>;tag=423C4FD0-270B To: <sip:001669228XXXX@121.244.230.10> Date: Wed, 22 Jan 2020 10:00:38 GMT Call-ID: DB899366-3C3411EA-9A30B8E4-830712E5@10.196.236.238 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 3683186494-1010045418-2586491108-2198278885 User-Agent: Cisco-SIPGateway/IOS-12.x Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 101 INVITE Timestamp: 1579687238 Contact: <sip:142442XXXX4@10.196.236.238:5060> Expires: 180 Allow-Events: telephone-event Max-Forwards: 69 Session-Expires: 1893 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 302 v=0 o=CiscoSystemsSIP-GW-UserAgent 6755 2217 IN IP4 10.196.236.238 s=SIP Call c=IN IP4 10.196.236.238 t=0 0 m=audio 28062 RTP/AVP 0 100 101 c=IN IP4 10.196.236.238 a=rtpmap:0 PCMU/8000 a=rtpmap:100 X-NSE/8000 a=fmtp:100 192-194 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=ptime:20 SIP: (3543926) Group (a= group line) attribute, level 65535 instance 1 not found. Jan 22 10:00:46.241: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:001669228XXXX@121.244.230.10:5060 SIP/2.0 Via: SIP/2.0/UDP 10.196.236.238:5060;branch=z9hG4bK266A7D162 Remote-Party-ID: "SIP TEST" <sip:142442XXXX4@10.196.236.238>;party=calling;screen=no;privacy=off From: "SIP TEST" <sip:142442XXXX4@10.196.236.238>;tag=423C4FD0-270B To: <sip:001669228XXXX@121.244.230.10> Date: Wed, 22 Jan 2020 10:00:46 GMT Call-ID: DB899366-3C3411EA-9A30B8E4-830712E5@10.196.236.238 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 3683186494-1010045418-2586491108-2198278885 User-Agent: Cisco-SIPGateway/IOS-12.x Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 101 INVITE Timestamp: 1579687246 Contact: <sip:142442XXXX4@10.196.236.238:5060> Expires: 180 Allow-Events: telephone-event Max-Forwards: 69 Session-Expires: 1893 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 302 v=0 o=CiscoSystemsSIP-GW-UserAgent 6755 2217 IN IP4 10.196.236.238 s=SIP Call c=IN IP4 10.196.236.238 t=0 0 m=audio 28062 RTP/AVP 0 100 101 c=IN IP4 10.196.236.238 a=rtpmap:0 PCMU/8000 a=rtpmap:100 X-NSE/8000 a=fmtp:100 192-194 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=ptime:20 SIP: (3543926) Group (a= group line) attribute, level 65535 instance 1 not found. Jan 22 10:01:02.241: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:001669228XXXX@121.244.230.10:5060 SIP/2.0 Via: SIP/2.0/UDP 10.196.236.238:5060;branch=z9hG4bK266A7D162 Remote-Party-ID: "SIP TEST" <sip:142442XXXX4@10.196.236.238>;party=calling;screen=no;privacy=off From: "SIP TEST" <sip:142442XXXX4@10.196.236.238>;tag=423C4FD0-270B To: <sip:001669228XXXX@121.244.230.10> Date: Wed, 22 Jan 2020 10:01:02 GMT Call-ID: DB899366-3C3411EA-9A30B8E4-830712E5@10.196.236.238 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 3683186494-1010045418-2586491108-2198278885 User-Agent: Cisco-SIPGateway/IOS-12.x Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 101 INVITE Timestamp: 1579687262 Contact: <sip:142442XXXX4@10.196.236.238:5060> Expires: 180 Allow-Events: telephone-event Max-Forwards: 69 Session-Expires: 1893 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 302 v=0 o=CiscoSystemsSIP-GW-UserAgent 6755 2217 IN IP4 10.196.236.238 s=SIP Call c=IN IP4 10.196.236.238 t=0 0 m=audio 28062 RTP/AVP 0 100 101 c=IN IP4 10.196.236.238 a=rtpmap:0 PCMU/8000 a=rtpmap:100 X-NSE/8000 a=fmtp:100 192-194 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=ptime:20 Jan 22 10:01:34.241: //3543926/DB88F73E9A2A/SIP/Error/act_sentinvite_wait_100: Out of retries Jan 22 10:01:34.241: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG: No Inbound Container Created !!! Jan 22 10:01:34.241: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931: No Inbound Container Created !!! Jan 22 10:01:34.241: //3543926/DB88F73E9A2A/SIP/Error/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Invalid CCB/Data/Container Jan 22 10:01:34.241: //3543926/DB88F73E9A2A/SIP/Error/sipAddSipContainerToCallEntry: Unable to add passthru hdrs to container Jan 22 10:01:34.241: //3543926/DB88F73E9A2A/CCAPI/cc_api_call_disconnected: Cause Value=102, Interface=0x13684C28, Call Id=3543926 Jan 22 10:01:34.241: //3543926/DB88F73E9A2A/CCAPI/cc_api_call_disconnected: Call Entry(Responsed=TRUE, Cause Value=102, Retry Count=0) Jan 22 10:01:34.241: //3543925/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources: release reserved xcoding resource. Jan 22 10:01:34.241: //3543926/DB88F73E9A2A/CCAPI/ccCallSetAAA_Accounting: Accounting=0, Call Id=3543926 Jan 22 10:01:34.241: //3543926/DB88F73E9A2A/CCAPI/ccCallDisconnect: Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=102) Jan 22 10:01:34.241: //3543926/DB88F73E9A2A/CCAPI/ccCallDisconnect: Cause Value=102, Call Entry(Responsed=TRUE, Cause Value=102) Jan 22 10:01:34.241: //3543926/DB88F73E9A2A/CCAPI/cc_api_call_disconnect_done: Disposition=0, Interface=0x13684C28, Tag=0x0, Call Id=3543926, Call Entry(Disconnect Cause=102, Voice Class Cause Code=0, Retry Count=0) Jan 22 10:01:34.241: //3543926/DB88F73E9A2A/CCAPI/cc_api_call_disconnect_done: Call Disconnect Event Sent Jan 22 10:01:34.241: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa: Jan 22 10:01:34.241: :cc_free_feature_vsa freeing 163FF8B0 Jan 22 10:01:34.241: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa: Jan 22 10:01:34.241: vsacount in free is 1 Jan 22 10:01:34.241: //3543925/DB88F73E9A2A/CCAPI/ccCallDisconnect: Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0) Jan 22 10:01:34.241: //3543925/DB88F73E9A2A/CCAPI/ccCallDisconnect: Cause Value=102, Call Entry(Responsed=TRUE, Cause Value=102) Jan 22 10:01:34.241: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 408 Request Timeout Via: SIP/2.0/UDP 8.28.0.71:8115;branch=z9hG4bKaPjvpZq2iyf From: "SIP TEST" <sip:142442XXXX4@8.20.XX.YY:6055>;tag=bF1uQiuSRLMcK To: <sip:911669228XXXX@8.28.0.71:8115>;tag=423D47DC-4FF Date: Wed, 22 Jan 2020 10:00:30 GMT Call-ID: bUMBus4xMTUj CSeq: 1286749321 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-12.x Reason: Q.850;cause=102 Content-Length: 0 Jan 22 10:01:34.489: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname i bucket 16 c_hname Call-ID bucket 14 Jan 22 10:01:34.489: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname f bucket 13 c_hname From bucket 4 Jan 22 10:01:34.489: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname t bucket 8 c_hname To bucket 11 Jan 22 10:01:34.489: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname l bucket 0 c_hname Content-Length bucket 8 Jan 22 10:01:34.489: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname v bucket 10 c_hname Via bucket 15 Jan 22 10:01:34.489: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ACK sip:911669228XXXX@182.75.YY.XXX:5060;user=phone SIP/2.0 i: bUMBus4xMTUj f: "SIP TEST" <sip:142442XXXX4@8.20.XX.YY:6055>;tag=bF1uQiuSRLMcK t: <sip:911669228XXXX@8.28.0.71:8115>;tag=423D47DC-4FF CSeq: 1286749321 ACK Max-Forwards: 70 User-Agent: eSLEE/0.13.98.6 l: 0 v: SIP/2.0/UDP 8.28.0.71:8115;branch=z9hG4bKaPjvpZq2iyf Jan 22 10:01:34.489: //3543925/DB88F73E9A2A/CCAPI/cc_api_call_disconnect_done: Disposition=0, Interface=0x13684C28, Tag=0x0, Call Id=3543925, Call Entry(Disconnect Cause=102, Voice Class Cause Code=0, Retry Count=0) Jan 22 10:01:34.489: //3543925/DB88F73E9A2A/CCAPI/cc_api_call_disconnect_done: Call Disconnect Event Sent Jan 22 10:01:34.489: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa: Jan 22 10:01:34.489: :cc_free_feature_vsa freeing 163FF990 Jan 22 10:01:34.493: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa: Jan 22 10:01:34.493: vsacount in free is 0 Jan 22 10:03:01.310: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: OPTIONS sip:100@182.75.YY.XXX SIP/2.0 Via: SIP/2.0/UDP 5.196.198.36:5061;branch=z9hG4bK-2078770072;rport Content-Length: 0 From: "sipvicious"<sip:100@1.1.1.1>;tag=6236346233336331313363340132393132343531383639 Accept: application/sdp User-Agent: friendly-scanner To: "sipvicious"<sip:100@1.1.1.1> Contact: sip:100@5.196.198.36:5061 CSeq: 1 OPTIONS Call-ID: 670827870465272336072838 Max-Forwards: 70 Jan 22 10:03:01.310: //3543927/35488BB59A31/SIP/Error/sipSPICheckReliableProvStringtag: Unable to access supported header values Jan 22 10:03:01.310: //-1/xxxxxxxxxxxx/SIP/Error/rtpAvpCodec_to_voipCodec: Unexpected RTP PayloadType :255 in SDP Body Jan 22 10:03:01.310: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/UDP 5.196.198.36:5061;branch=z9hG4bK-2078770072;rport From: "sipvicious"<sip:100@1.1.1.1>;tag=6236346233336331313363340132393132343531383639 To: "sipvicious"<sip:100@1.1.1.1>;tag=423E9BF8-1984 Date: Wed, 22 Jan 2020 10:03:01 GMT Call-ID: 670827870465272336072838 Server: Cisco-SIPGateway/IOS-12.x CSeq: 1 OPTIONS Supported: 100rel,resource-priority,replaces,sdp-anat Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event Accept: application/sdp Content-Type: application/sdp Content-Length: 173 v=0 o=CiscoSystemsSIP-GW-UserAgent 1169 9025 IN IP4 10.196.236.238 s=SIP Call c=IN IP4 10.196.236.238 t=0 0 m=audio 0 RTP/AVP 18 0 8 9 4 2 15 c=IN IP4 10.196.236.238
01-22-2020 04:31 AM
I'm not seeing any reply to your outbound Invites. The gateway tries seven times before giving up. First thing I'd suggest is checking that your traffic is being sent sourced on the correct interface. If it's not then the service provider either won't recognise your gateway, or won't be able to reply as the IP address would be meaningless. Is there a firewall between your gateway and the ITSP?
01-23-2020 05:38 AM
No Tony, There are no firewalls In between. I will check the traffic source and confirm.
11-04-2024 02:36 AM
What was the resolution please? We just installed Meraki MX on several sites, and we get intermittent issues where outgoing calls fail, but incoming calls work.
