Voice Translation problem
Pierrot.damen
For our emergency numbers we need to send 1992(emergency Number)(zipcode) out.
i've made a route pattern on the cucm: 1XX transforms to 1992(zip)1XX (format required by provider)
i'm trying to swap the order of the digits on the cube with this translation rule "rule 1 /(1992\)(....\)(1..\)/ /\1\3\2/ "
but it's not accepting this translation rule
Any help would be appreciated!
Pierrot
or if you want to do it your way, just ensure you have put backslash correctly as follows;
rule 1 /\(1992\)\(....\)\(1..\)/ /\1\3\2/
- Vivek
5 Replies 5
Vivek Batra
Can you also quote an example like;
What user will dial?
What all manipulations you've applied in CUCM and where (on route pattern, route list etc)?
- Vivek
ex1.
User will dial 100 or 0100 on his phone. this will go to the cube as 19929150100 if the user is located in the 9150 zipcode. where it needs to be transformed to 19921009150.
ex2
User will dial 112 or 0112 on his phone. this will go to the cube as 19929150112 if the user is located in the 9150 zipcode. where it needs to be transformed to 19921129150.
I applied a route pattern for 0.1XX and 1XX to 199291501XX
is this what you mean?
regards,
Pierrot
Perfect...
Try the following;
rule 1 /^1992\(....\)\(1..$\)/ /1992\2\1/
- Vivek
- Vivek
Thx Vivek! that did the trick. :)
Got it working now
