12-12-2014 03:26 AM - edited 03-17-2019 01:18 AM
Hii,
I have a Unity 8.6 and I active the voicemal for 10 user but I have some problems with notifications on the devices. The Phones are 6945 and 7841.
The problem is when I have a voice mail on the phone I don't have any message indicators ( light/missed call etc)
Pls see attachments:
Solved! Go to Solution.
12-12-2014 05:45 AM
Ciao.
In your port group config you defined 5998 as MWI off extension while on cucm you defined 5998 as MWI on...
Please correct it and all should work
Carlo
12-12-2014 05:20 AM
Hi.
Did you also defined MWI numbers on CUC port group configuration?
Let me know
Carlo
12-12-2014 05:36 AM
12-12-2014 05:40 AM
Hi.
basically you don't need 1 port for each VM user because each port is a channel to CUC...
Of course, if 20 calls arrive concurrently to those 20 phones and all are forwarded to the VM, you would need 20 VM ports.
Carlo
12-12-2014 05:45 AM
Ciao.
Carlo
12-15-2014 01:12 AM
