03-21-2016 11:57 AM - edited 03-18-2019 11:53 AM
Hi all, I've got a total N00b question, and inherited this setup... I am very new to telephony so limited experience on this front.
I have a Cisco 2921 with a
NAME: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 1", DESCR: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1" in slot 0/1/0.
The PRI seems to be active:
ISDN Serial0/1/0:23 interface
dsl 1, interface ISDN Switchtype = primary-ni
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 1 CCBs = 0
The Free Channel Mask: 0x807FFFFF
Number of L2 Discards = 0, L2 Session ID = 16
Total Allocated ISDN CCBs = 0
My brief config:
controller T1 0/1/0
cablelength long 0db
pri-group timeslots 1-24 service mgcp
interface Serial0/1/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
voice-port 0/1/0:23
I also have a cucm setup in my HQ office with all these IP Phones setup there.
In looking at this config i show some dial-peer configs (shown below):
I'm assuming if i dial 911 or 9,410,xxx-xxxx the router will send this call across the local PRI rather than the MPLS line to my home office. Is this true? The area code 410 is in baltimore and not sure why a LD call specific to this area code would traverse the PRI rather than the MPLS. I understand that 911 is setup this way for emergency, but why the 410?
Secondly the dial-peer 512 is the local area code in Austin (my branch office), but the translation-profile is setup with 'local' rather than "LOCAL". Is case sensitivity important? With this dial-peer will this send all my local calls across this PRI?
Any clarification is appreciated.
dial-peer voice 911 pots
translation-profile outgoing ANI
destination-pattern 911$
port 0/1/0:23
forward-digits 3
dial-peer voice 9410 pots
translation-profile outgoing LOCAL
destination-pattern 9410.......$
port 0/1/0:23
forward-digits 10
dial-peer voice 512 pots
translation-profile outgoing local
destination-pattern 9512.......$
port 0/1/0:23
forward-digits 10
03-21-2016 12:08 PM
I suggest you post your full config, those dial-peers will not be used by that PRI, unless you have SRST. That PRI is handled by MGCP on CUCM, so CUCM is the one that takes care of all the routing, the PRI will just do whatever CUCM says.
No way to tell you anything with just bits and pieces of the config.
03-21-2016 12:18 PM
Thanks Jamie, I agree (i did clear a few password and other unnecessary things per our security policy).
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2016.03.21 14:11:01 =~=~=~=~=~=~=~=~=~=~=~=
term len 0
Austin-MPLS#sh run
Building configuration...
Current configuration : 16700 bytes
! Last configuration change at 00:19:48 CST Thu Feb 18 2016
! NVRAM config last updated at 08:16:10 CST Sun Dec 13 2015
version 15.2
service password-encryption
hostname Austin-MPLS
boot-start-marker
boot-end-marker
card type t1 0 0
card type t1 0 1
logging buffered 100000
no logging console
no logging monitor
enable password 7 082
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login console-login local
aaa authentication login http group tacacs+ local
aaa authentication enable default enable
aaa authorization exec default group tacacs+ local
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default stop-only group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
clock timezone CST -6 0
clock summer-time CDT recurring
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 T1 0/0/0
no ipv6 cef
no ip source-route
ip flow-cache timeout active 1
ip domain list corporate.
no ip domain lookup
ip domain name corporate.
ip name-server 172.16.82.10
ip name-server 172.18.82.10
ip cef
ip wccp 61 redirect-list WAAS_Redirects
ip wccp 62 redirect-list WAAS_Redirects
crypto pki trustpoint TP-self-signed-4165044240
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4165044240
revocation-check none
rsakeypair TP-self-signed-4165044240
quit
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/1.136
bind media source-interface GigabitEthernet0/1.136
registrar server
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
h225 timeout tcp establish 3
voice register global
max-dn 200
max-pool 50
voice register pool 1
id network 172.29.136.0 mask 255.255.255.0
application sip.app
dtmf-relay sip-notify
codec g711ulaw
voice translation-rule 1
rule 1 // /512320/
voice translation-rule 2
rule 1 // // type any subscriber plan any isdn
voice translation-rule 3
rule 1 // // type any national plan any isdn
voice translation-rule 4
rule 1 // // type any international plan any isdn
voice translation-profile ANI
translate calling 1
voice translation-profile INT
translate calling 1
translate called 4
voice translation-profile LD
translate calling 1
translate called 3
voice translation-profile LOCAL
translate calling 1
translate called 2
voice translation-profile my_profile
translate called 1
license udi pid CISCO2921/K9 sn FTX16
hw-module pvdm 0/0
hw-module sm 1
username network.admin privilege 15 passwor
redundancy
controller T1 0/0/0
controller T1 0/0/1
channel-group 0 timeslots 1-24
controller T1 0/0/2
controller T1 0/0/3
controller T1 0/1/0
controller T1 0/1/1
ip ssh version 2
class-map match-any QoS-VoIP-Control
match ip dscp cs3
match ip dscp af31
match access-group name Voice-Control
class-map match-any QoS-VoIP-RTP
match ip dscp ef
match protocol rtp audio
class-map match-any QoS-Video-RTP
match protocol rtp video
policy-map QoS-Policy
class QoS-VoIP-RTP
priority percent 30
set ip precedence 5
class QoS-Video-RTP
priority percent 10
set ip precedence 4
class QoS-VoIP-Control
bandwidth percent 20
set ip precedence 3
class class-default
set ip precedence 0
fair-queue
interface Loopback11
ip address 10.200.111.203 255.255.255.255
interface Multilink1
description CenturyLink MPLS
no ip address
ip nbar protocol-discovery
ip flow monitor NETFLOW_MONITOR input
ip flow monitor NETFLOW_MONITOR output
ip flow ingress
ip flow egress
shutdown
ppp multilink
ppp multilink group 1
no cdp enable
service-policy output QoS-Policy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description G0/0 INAC: **100Mb CenturyLink MPLS Circuit ID: xxxx **
bandwidth 100000
ip address 63.145.123.170 255.255.255.252
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly in
duplex full
speed 100
description G0/1 UP: ** 1Gb Uplink to Austin1 G1/0/1**
no ip address
ip flow ingress
ip flow egress
duplex auto
speed auto
description Austin VOICE
encapsulation dot1Q 136
ip address 172.29.136.1 255.255.255.0
ip helper-address 172.16.82.59
ip pim sparse-dense-mode
ip flow ingress
ip flow egress
interface GigabitEthernet0/1.236
description Austin LAN
encapsulation dot1Q 236
ip address 172.29.236.1 255.255.255.0
ip wccp 61 redirect in
ip flow ingress
ip flow egress
interface GigabitEthernet0/1.336
encapsulation dot1Q 336
ip address 10.200.112.9 255.255.255.248
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
no cdp enable
interface Serial0/0/1:0
no ip address
ip flow ingress
ip flow egress
encapsulation ppp
shutdown
ppp multilink
ppp multilink endpoint mac GigabitEthernet0/0
no cdp enable
interface Serial0/0/2:0
no ip address
ip flow ingress
ip flow egress
encapsulation ppp
shutdown
ppp multilink
no cdp enable
interface Serial0/0/3:0
no ip address
ip flow ingress
ip flow egress
encapsulation ppp
shutdown
ppp multilink
no cdp enable
no ip address
encapsulation hdlc
no cdp enable
interface SM1/0
ip address 192.168.10.9 255.255.255.252
ip wccp redirect exclude in
ip flow ingress
ip flow egress
service-module ip address 192.168.10.10 255.255.255.252
!Application: Restarted at Sun Dec 13 14:15:10 2015
service-module ip default-gateway 192.168.10.9
interface SM1/1
description Internal switch interface connected to Service Module
no ip address
interface Vlan1
no ip address
interface Vlan335
no ip address
router bgp 65128
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor 63.145.123.169 remote-as 209
address-family ipv4
network 10.64.20.0 mask 255.255.255.0
network 10.200.111.203 mask 255.255.255.255
network 10.200.112.8 mask 255.255.255.248
network 10.200.121.235 mask 255.255.255.255
network 172.29.236.0 mask 255.255.255.0
network 192.168.10.8 mask 255.255.255.252
neighbor 63.145.123.169 activate
neighbor 63.145.123.169 send-community
exit-address-family
ip forward-protocol nd
ip bgp-community new-format
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-export source SM1/0
ip flow-export version 9
ip flow-export destination 172.16.158.8 2055
ip flow-export destination 172.21.14.136 9995
ip route 0.0.0.0 0.0.0.0 63.145.123.169 254
ip route 10.64.20.0 255.255.255.0 172.29.236.11
ip route 10.200.121.235 255.255.255.255 Null0
ip access-list standard xxx_Monitor
permit 161.89.160.115
permit 161.89.160.116
permit 162.89.160.117
permit 161.89.151.222
permit 161.89.150.220
permit 161.89.151.221
permit 161.89.151.220
ip access-list standard xxx_SNMP
permit 172.16.82.245
permit 172.16.158.6
permit 172.16.158.7
permit 172.16.158.4
permit 172.16.158.5
permit 172.16.158.8
permit 172.16.158.9
permit 172.18.82.165
permit 151.148.64.46
permit 172.18.82.145
permit 172.18.97.14
permit 172.18.127.26
permit 172.16.127.0 0.0.0.255
ip access-list standard SNMP
permit 172.18.97.14
permit 172.16.158.0 0.0.0.255
permit 172.16.168.0 0.0.0.255
ip access-list standard VTY
permit 161.89.160.119
permit 161.89.151.6
permit 161.89.151.5
permit 161.89.151.226
permit 172.18.97.14
permit 172.29.236.0 0.0.0.255
permit 161.89.145.208 0.0.0.15
permit 161.89.146.0 0.0.0.255
ip access-list extended xxx_MGMT
permit ip host 172.29.236.2 161.89.151.0 0.0.0.255
permit ip host 172.29.236.2 161.89.160.0 0.0.0.255
ip access-list extended Voice-Control
permit tcp any any eq 1720
permit tcp any any range 11000 11999
permit udp any any eq 2427
permit tcp any any eq 2428
permit tcp any any range 2000 2002
permit udp any any eq 1719
permit udp any any eq 5060
ip access-list extended WAAS_Redirects
permit tcp any 172.29.236.0 0.0.0.255
permit tcp 172.26.236.0 0.0.0.255 any
ip sla responder
ip sla 1
udp-jitter 209.45.202.58 32000 source-ip 63.234.161.70 source-port 32000 codec g711ulaw
tos 160
tag Austin to PDC
frequency 30
history distributions-of-statistics-kept 10
ip sla schedule 1 life forever start-time now
ip sla 2
udp-jitter 209.45.202.110 32000 source-ip 63.234.161.70 source-port 32000 codec g711ulaw
tos 160
tag Austin to TDC
frequency 30
ip sla schedule 2 life forever start-time now
logging trap warnings
logging facility syslog
logging 172.16.127.11
logging 172.16.127.28
logging 172.18.97.14
access-list 23 permit 10.10.10.0 0.0.0.7
route-map xxx_MGMT permit 10
match ip address xxx_MGMT
control-plane
voice-port 0/0/0:23
voice-port 0/1/0:23
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
ccm-manager fallback-mgcp
ccm-manager redundant-host 172.16.91.12 172.18.91.11
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 172.18.91.11 172.18.91.12
ccm-manager config
mgcp
mgcp call-agent 172.18.91.12 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp bind control source-interface GigabitEthernet0/1.136
mgcp bind media source-interface GigabitEthernet0/1.136
mgcp profile default
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
port 0/1/0:23
forward-digits 3
port 0/1/0:23
forward-digits 10
dial-peer voice 9443 pots
destination-pattern 9443.......$
port 0/1/0:23
forward-digits 10
dial-peer voice 9667 pots
destination-pattern 9667.......$
port 0/1/0:23
forward-digits 10
dial-peer voice 11 pots
translation-profile outgoing LD
destination-pattern 91[2-9].........$
port 0/1/0:23
forward-digits 11
dial-peer voice 9011 pots
translation-profile outgoing INT
destination-pattern 9011T
port 0/1/0:23
prefix 011
dial-peer voice 100 pots
translation-profile incoming my_profile
incoming called-number .
direct-inward-dial
port 0/1/0:23
port 0/1/0:23
forward-digits 10
gatekeeper
shutdown
banner motd ^C
*** NOTICE TO ALL USERS ***
^C
line con 0
login authentication console-login
stopbits 1
line aux 0
stopbits 1
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
line vty 0 4
access-class VTY in
privilege level 15
password 7 08261F5A
transport input ssh
line vty 5 15
access-class VTY in
privilege level 15
password 7 08261F5A5
transport input ssh
scheduler allocate 20000 1000
ntp authentication-key 1 md5 075F78186A5D3D507E7C7078 7
ntp authenticate
ntp trusted-key 1
ntp update-calendar
ntp server 192.168.1.1 key 1
ntp server 192.168.1.2 key 1
ntp server 192.168.1.21 key 1
end
Austin-MPLS#
03-21-2016 12:32 PM
Well, whoever did this, did a messy job, it seems that both of your PRIs are supposed to be MGCP, you can confirm that in the CUCM config, but one is lacking config, if they're both supposedly MGCP
This is a good config:
no ip address
encapsulation hdlc
isdn bind-l3 ccm-manager <---- notice this command, which binds L3 to MGCP, as it has to be
no cdp enable
controller T1 0/1/0
This is a half cooked config
controller T1 0/0/0
no ip address
encapsulation hdlc
no cdp enable
Not sure if you have/had another port for MGCP
service mgcpapp
port 0/2/0
You also seem to have what might have been an attempt for SRST, but just as with the above PRI, is not fully configured
Right now those dial-peers and translation rules, seem to be doing absolutely nothing, as they're supposed to use the PRI which is controlled by MGCP.
You might want to ask around if someone has some idea of what that ISR is supposed to do before removing and adjusting that config.
