XML Path Problem
Ivan131984
I have tried to make a script to read an xml file but I cannot read it because the strucuture of the xml is the following
<?xml version="1.0" encoding="utf-8"?>
<Empleados xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance " xmlns:xsd="http://www.w3.org/2001/XMLSchema">
  <empleado/>
    <resultado>00</resultado>
    <nombre>Rose Marie</nombre>
    <apellido>Reyes Duque</apellido>
    <nivel>05</nivel>
    <sede>Profesional Call Center TI</sede>
    <cargo></cargo>
    <descripcion></descripcion>
  </empleado>
</Empleados>
When I tried to read the xml the scritp returns null, and I know the problem is because for the attributes  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance " xmlns:xsd="http://www.w3.org/2001/XMLSchema"> because when I remove those attributes it works fine. The problem is that my customer says that he cannot remove those attributes.
Anyone have any idea how can I read the xml with this structure ??. Thanks.
marbash
Hi Ivan,
I have exactly the same problem. Please, update if you managed to resolve it.
Mustafa
