Hardware for CUCM 6.1
Jayd000007
We will be migrating our CCM from 4.1(3) to 6.1. we will buy new Hardware (an IBM Server) wich need to be the same as the MCS-7835(single CPU).
Which one would fit best this discription?
. IBM X345 Single Processor (IBM xSeries 345/1 CPU 8670 [2400 MHz])
• IBM X345 Single Processor (IBM xSeries 345/1 CPU 8670 [3.06 GHz])
• IBM X346 Single Processor (IBM xSeries 346/1 CPU 8670 [3.4 GHz])
• IBM X345 Dual Processor (IBM xSeries 345 8670-71x [3.06 GHz])
• IBM X346 Dual Processor (IBM xSeries 346/2 CPU 8840 [3.4 GHz])
• IBM x3650 Single Processor (IBM xSeries 3650, Intel 5140 2.33 GHz)
• IBM x3650 Dual Processor (IBM xSeries 3650, Intel 5140 2.33 GHz)
Here's the information I have found -
• IBM X345 Single Processor (IBM xSeries 345/1 CPU 8670 [2400 MHz]) - 7835 Equivalent
• IBM X345 Single Processor (IBM xSeries 345/1 CPU 8670 [3.06 GHz]) - 7835 Equivalent
• IBM X346 Single Processor (IBM xSeries 346/1 CPU 8670 [3.4 GHz]) - 7835I1 Equivalent
• IBM X345 Dual Processor (IBM xSeries 345 8670-71x [3.06 GHz]) - 7845 Equivalent
• IBM X346 Dual Processor (IBM xSeries 346/2 CPU 8840 [3.4 GHz]) - 7845 Equivalent
• IBM x3650 Single Processor (IBM xSeries 3650, Intel 5140 2.33 GHz) - 7835I2 Equivalent
• IBM x3650 Dual Processor (IBM xSeries 3650, Intel 5140 2.33 GHz) - 7845I2 Equivalent
I would go for "IBM X346 Single Processor (IBM xSeries 346/1 CPU 8670 [3.4 GHz])" server.
-> Sushil
just as a side note to the info Sushil has provided we have some tables on that, not sure if you have checked them out
Cisco Unified Communications Manager Server Support Matrix
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
javalenc
if this helps, please rate
java
Ok so im going for the IBM xSeries 346 (Single-Processor 3.4 GHz). Now i went trough this document:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/product_solution_overview0900aecd80091615.html
and the server is listed two times!!, which one should i take? and do i need just to order the server and all the component showed in the Table??
