6to4 on 1841 doesn't work
sachatreffer
Hy everyone,
My english is not verry good, but I do the best I can.
There is my Infrastructure
Schema
For information, the link between the 1841 and the 3560 is in IPv6
My local area works, I can ping every devices and every hosts. What I want to do is to connect the hosts (only IPv6) with the "IPv6 NET" trought an IPv4 access. For doing it, I'm using 6to4 and I folow the commands here.
I can't communicate with outside and I don't know why.
Someone could help me please ?
My 1841 configurations:
Building configuration...
Current configuration : 1702 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$1PUw$zDwFcBZjklxBuVvQe3DJl1
enable password *******
no aaa new-model
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ipv6 unicast-routing
interface Tunnel10
 no ip address
 no ip redirects
 ipv6 address 2002:5503:D70::1/48
 tunnel source FastEthernet0/1
 tunnel mode ipv6ip 6to4
interface FastEthernet0/0
 no ip address
 duplex auto
 speed auto
 ipv6 address FD4F:ABD4:AB05:FFFF::2/64
 ipv6 enable
 ipv6 nd prefix FD4F:ABD4:AB05:FFFF::/64
 ipv6 nd managed-config-flag
 ipv6 nd other-config-flag
 ipv6 dhcp relay destination FD4F:ABD4:AB05:6A14::FFFF
interface FastEthernet0/1
 ip address dhcp client-id FastEthernet0/1 hostname 1841
 duplex auto
 speed auto
interface FastEthernet0/0/0
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
 no ip address
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
ip http server
no ip http secure-server
ipv6 route 2002::/16 FastEthernet0/1
ipv6 route 2000::/3 FastEthernet0/1
ipv6 route FD4F:ABD4:AB05:115E::/64 FD4F:ABD4:AB05:FFFF::1
ipv6 route FD4F:ABD4:AB05:6A14::/64 FD4F:ABD4:AB05:FFFF::1
ipv6 route FD4F:ABD4:AB05:EC96::/64 FD4F:ABD4:AB05:FFFF::1
ipv6 route FD4F:ABD4:AB05:FFFE::/64 FD4F:ABD4:AB05:FFFE::3
ipv6 route FD4F:ABD4:AB05:FFFF::/64 FastEthernet0/0
ipv6 route ::/0 FastEthernet0/1
control-plane
line con 0
 password ******
 login
line aux 0
line vty 0 4
 login
scheduler allocate 20000 1000
end
and the routes
IPv6 Routing Table - 9 entries
Codes: C - Connected, L - Local, S - Static, R - RIP, B - BGP
       U - Per-user Static route
       I1 - ISIS L1, I2 - ISIS L2, IA - ISIS interarea, IS - ISIS summary
       O - OSPF intra, OI - OSPF inter, OE1 - OSPF ext 1, OE2 - OSPF ext 2
       ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2
C   2002:5503:D70::/48 [0/0]
     via ::, Tunnel10
L   2002:5503:D70::1/128 [0/0]
     via ::, Tunnel10
S   FD4F:ABD4:AB05:115E::/64 [1/0]
     via FD4F:ABD4:AB05:FFFF::1
S   FD4F:ABD4:AB05:6A14::/64 [1/0]
S   FD4F:ABD4:AB05:EC96::/64 [1/0]
C   FD4F:ABD4:AB05:FFFF::/64 [0/0]
     via ::, FastEthernet0/0
L   FD4F:ABD4:AB05:FFFF::2/128 [0/0]
L   FE80::/10 [0/0]
     via ::, Null0
L   FF00::/8 [0/0]
     via ::, Null0
Sacha Treffer
Seb Rupik
Hi Sacha,
I'll admit I have never delpoyed 6RD, but I can tell you you design is missing some key components.
In a 6RD network your 1841 is (one of many) CE routers, but you need a BR router as part of your 6RD domain which will receive your encapsulated traffic and forward it into a dual-stack v4/v6 network, off to the internet.
Without a BR router and a tunnel endpoint you cannot forward traffic.
Do you have a secondary site which is dual-stack? If not you may want to look at:
NAT64/DNS64 which in your case would need to translate all IPv6 traffic into IPv4, perhaps not ideal for a production network?
Or ipv6ip tunnels which would send your IPv6 traffic to a third-party tunnel endpoint. From security perspective perhaps not ideal?
cheers,
Seb.
Sacha
It's not very clear what you are trying to do
are you trying to setup 6to4 relay ?
do you have a global unicast ipv6 block ?
Fdf4 from my knowledge is not something you should use
lastly 6to4 is an old technology being deprecated. You should ask your isp for native v6 or if this is not possible, you can use a static tunnel over the v4 internet to a tunnelbroker like hurricane electric or sixxs
Hope this helps
mark
