7206 vxr g2 bgp ipv6 address-family creation problem
Umit AYDINLI
Hi All,
I have a cisco 7206 vxr on the bgp connection. I can try to on the bgp create address-family ipv6 unicast but i see error % BGP: Error initializing topology. I'm using ios version c7200p-spservicesk9-mz.122-33.SRD2.bin
My configrations are below:
ipv6 unicast-routing
ipv6 cef
interface Loopback3
ip address 10.230.238.133 255.255.255.252
router bgp 65536
bgp log-neighbor-changes
neighbor 10.230.238.134 remote-as 100
neighbor 10.230.238.134 description ***
neighbor 10.230.238.134 update-source Loopback3
address-family ipv4
  no synchronization
  network 172.17.0.0 mask 255.255.255.0
  neighbor 10.230.238.134 activate
  neighbor 10.230.238.134 default-originate
  neighbor 10.230.238.134 distribute-list 22 out
  neighbor 10.230.238.134 route-map in in
  neighbor 10.230.238.134 route-map Out out
  no auto-summary
exit-address-family
7206_VXR_G2#conf
Configuring from terminal, memory, or network [terminal]?
Enter configuration commands, one per line.  End with CNTL/Z.
7206_VXR(config-router)#address-family ?
  ipv4   Address family
  ipv6   Address family
  l2vpn  Address family
  nsap   Address family
  vpnv4  Address family
  vpnv6  Address family
7206_VXR(config-router)#address-family ipv6 unicast
What is my false?
Deepak Ambotkar
Umit,
I think IPv6 unicast is enabled when you did "ipv6 unicast-routing" in the global config mode.
why don't you try to just configure it as "address family ipv6" (as default).
Also you can try to update the software to the following:-
Description:ADVANCED ENTERPRISE SERVICES
Release:15.2.4S
Release Date:26/Jul/2012
File Name:c7200p-adventerprisek9-mz.152-4.S.bin
Min Memory:DRAM 1024 MB Flash 256 MB
Size:35.52 MB (37250244 bytes)
regards,
deepak
