Comcast prefix-delegation - LAN interfaces do not participate in RA
I am running a Cisco 3845 at home with IOS 151-4.M10.  I get my IPv6 address space from Comcast via:
interface GigabitEthernet0/0
 description Comcast Public
  ipv6 address dhcp
 ipv6 enable
 ipv6 dhcp client pd hint ::/60
 ipv6 dhcp client pd prefix-from-Comcast
 ipv6 inspect v6FWOUT out
 ipv6 traffic-filter v6_Access_In in
end
The LAN interfaces are able to get addresses via prefix-delegation, however I can't seem to make SLAAC work for clients attached to those interfaces.
interface GigabitEthernet0/1.1010
 encapsulation dot1Q 1010
 ipv6 address FE80::AAA link-local
 ipv6 address prefix-from-Comcast ::A:0:0:0:1/64
 ipv6 enable
 ipv6 nd autoconfig prefix
 ipv6 nd autoconfig default-route
end
Is there anything I'm missing?  I can ping via link-local addresses, so there is no physical connectivity problems.
5 Replies 5
Seb Rupik
Hi there,
Looks like you have configured Gi0/1.1010 to send out RS packets to receive RAs from other routers on the link. Instead, try the following:
int gi0/1.1010
  no ipv6 nd autoconfig prefix
  no ipv6 nd autoconofig default-route
  ipv6 nd prefix default
That should ensure your switch is the one sending out RA packets with default settings.
cheers,
Seb.
Hi Seb,
Thanks for your reply.  However this does not appear to resolve the issue.  I have essentially reverted back to defaults:
 ip address 10.50.100.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 ipv6 enable
end
The odd thing is that if I assign an address manually rather than through prefix-delegation, it still does not assign addresses, so it feels like it is more having to do with it being a sub-interface rather than it using prefix delegation.  I'm wondering if it is an IOS bug at this point.  Very strange!  I'll keep hammering away at it.
Hi Mattias,
What output do you get for:
sh ipv6 int gi0/1.1010
cheers,
Seb.
I get: (edited for privacy)
#show ipv6 interface gi0/1.1010
GigabitEthernet0/1.1010 is up, line protocol is up
  IPv6 is enabled, link-local address is FE80::226:CBFF:FEE9:BB31
  No Virtual link-local address(es):
  General-prefix in use for addressing
  Global unicast address(es):
    2601:xxxx:300:AAA::1, subnet is 2601:xxxx:300:AAA::/64 [CAL/PRE]
      valid lifetime 207758 preferred lifetime 207758
  Joined group address(es):
    FF02::1
    FF02::2
    FF02::1:FF00:1
    FF02::1:FFE9:BB31
  MTU is 1500 bytes
  ICMP error messages limited to one every 100 milliseconds
  ICMP redirects are enabled
  ICMP unreachables are sent
  Input features: Common pak subblock
  Output features: Firewall Inspection
  ND DAD is enabled, number of DAD attempts: 1
  ND reachable time is 30000 milliseconds (using 30000)
  ND advertised reachable time is 0 (unspecified)
  ND advertised retransmit interval is 0 (unspecified)
  ND router advertisements are sent every 200 seconds
  ND router advertisements live for 1800 seconds
  ND advertised default router preference is Medium
  Hosts use stateless autoconfig for addresses.
That output looks good.
If you run 'debug ipv6 nd' whilst a device is connected to the LAN, do you see any ICMPv6-ND messages relating to receiving RS packets?
Likewise if you run tcpdump/ wireshark on a connecting device, do you see Router Solicitations being sent? What about the periodic Router Advertisments packets every 200 seconds?
cheers,
Seb.
