Difference between Sh interface and sh run intface
deepak.nayak1
HI,
When I am checking sh run int gi0/0 duplex is auto, but when checked in sh int gi0/0 duplex is full.
Please let me know what is the meaning.
#sh run int Gi0/0
Building configuration...
Current configuration : 243 bytes
interface GigabitEthernet0/0
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
end
#sh int Gi0/0
GigabitEthernet0/0 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is 78da.6e83.5c20 (bia 78da.6e83.5c20)
     reliability 255/255, txload 14/255, rxload 174/255
  Keepalive set (10 sec)
  Full Duplex, 100Mbps, media type is RJ45
  output flow-control is XON, input flow-control is XON
B.kablawi90
Level 3
Level 3
Sho run interface
Displays the the configured value of the interface, so instead of making show run and find out the particular interface you can use the command #sho run interface Gi0/0 and it will tell you what is the running configuration under this port
show interface
Displays the the values and the statistics of the interface and the operational values such us IP address, MAC address, Media type, input / output error ...etc
So, you configured the port duplex auto, and shown in the show interface that it's duplex Full which mean it telling you the operational state of it. You make it auto and allowed it to negotiate with the connected port and based-on it chose to bell duplex Full
Try to configure
interface g0/0
duplex full or duplex half
and check the result
exaclty B.kablawi90 and it applies on the speed as well.
