IPv6 ACL problem with DNS
Bastiaan Tewis
Community Member
Hello everybody,
We are testing IPv6 at moment and now we having the following problem. When we apply security on the interface that is facing the internet the dns protocol doesn't work anymore. What we have configured is the follwing:
ipv6 inspect routing-header
ipv6 inspect udp idle-time 3600
ipv6 inspect tcp synwait-time 60
ipv6 inspect name ipv6-firewall tcp
ipv6 inspect name ipv6-firewall udp
ipv6 inspect name ipv6-firewall ftp timeout 3600
ipv6 inspect name ipv6-firewall icmp
ipv6 access-list ipv6-inet-in
remark block site local
deny ipv6 any FEC0::/10
remark block mcast
deny ipv6 any FF00::/8
remark permit mcast link local
permit ipv6 any FF02::/16
remark permit mcast global scope
permit ipv6 any FF0E::/16
remark permit minimal icmp messages
permit icmp any any echo-reply
permit icmp any any time-exceeded
permit icmp any any unreachable
permit icmp any any echo-request
permit icmp any any packet-too-big
permit icmp any any parameter-problem
permit icmp any any mld-query
permit icmp any any mld-report
permit icmp any any mld-reduction
permit icmp any any router-solicitation
permit icmp any any router-advertisement
remark permitted traffic
permit udp any any eq domain log
And the following is configured on the interface facing the internet
ipv6 traffic-filter ipv6-inet-in in
ipv6 inspect ipv6-firewall in
ipv6 inspect ipv6-firewall out
When this is configured the dns protocol does not working any more. In the debug we also seeing that the rule permit udp any any eq domain log on the access-list doesn't got any hits. The dns protocol is only working when we add the following line permit ipv6 host {ipv6 addres of dns server} any to the access-list, but that is not what you want. Do you have any suggestions what maybay be wrong with it?  PS. the router we are using is a cisco 887VA with IOS version 15.1(4)M5
In advanced Thank you
2 Accepted Solutions
Nagendra Kumar Nainar
The dns protocol is only working when we add the following line permit ipv6 host {ipv6 addres of dns server} any to the access-list"
So it appears that the ACL is hitting return traffic from DNS.
Can you try adding the below entry in ACL,
permit udp an eq domain any log
Nagendra
Julio Carvajal
From a security Point of view:
Okey, you are inspecting in both directions:
Should not be more secure just to inspect in the out direction and then filter traffic being generated on the outside interface with an ACL?
Now as Nagendra said the ACL syntax is wrong.
The traffic you are permitting right now is the DNS queries not the DNS replies with the A-record....
So change that ACL and u should be good to go.
Julio Carvajal
Remember to rate all of the helpful posts.
For this community that's as important as a thanks.
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Nagendra
Julio Carvajal
Julio Carvajal
Julio Carvajal
Thank you Nagendra and Julio Carvajal.
I have tested and it's working.
To Nagendra thank you for giving me the correct rule. To Julio Carvajal thank you for the explanation and you are right there is no reason for the ipv6 inspect ipv6-firewall in on the interface facing the internet. Also by anylazing the ACL rule i am now thinking wy i haven't seen that.
