IPV6 Routing Issue
Joshuabowers
Level 2
Level 2
I re created my topology in the packettracer program by cisco. My issue is that the PC can not ping a 2001:db8:Acad:B::1/64 address on the simulated ISP router. I tried multiple static/default routes on router0 and router1 with not luck. Can you look at my packet tracer file and explain what the issue is. I added a extra .zip to the file path so I can upload the file.
router 0 is a simulated ISP has one route for the R2 IPV6 address
router 1 is the Border router for Eigrp. has default route to ISP
Router 2 is a internal router
JF
Frequent Visitor
Frequent Visitor
The two routers Router0 & Router1 have static default route using interface :
ipv6 route ::/0 FastEthernet1/0
So when Routers0 want to contact a device that is not directly connected (the ping reply in your case), he send an NS (Neighbor Solicitation) to resolve the ipv6 address requested (like ARP in IPv4).
Router0#*mars 1 01:21:28.576: ICMPv6-ND: Sending NS for 2001:DB8:ACAD:12::1 on FastEthernet0/0
Router1#*mars 1 01:21:28.613: ICMPv6-ND: Received NS for 2001:DB8:ACAD:C::5 on FastEthernet0/0 from 2001:DB8:ACAD:12::1
But he doesn't have any answer ...
Try to configure static default routes using IPv6 address, it should work =>
ipv6 route ::/0 FastEthernet1/0 FE80::2
or
ipv6 route ::/0 2001:DB8:ACAD::X
Julio E. Moisa
Could you please upload the file, it shows an error message.
Thank you in advance.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
