Problem to configure DHCPV6 relay in Cisco Packet tracer 8.0.1.0064
shamik200068282
     Is there any way to configure DHCPV6 relay in CPT ver. 8.0.1.0064 (64-bit). I have tried to configure it on C4300, C2900 & C1900 router with the interface configuration mode command "ipv6 dhcp relay..."(I did't write the full command here) but there is no support for such command in interface mode. It will be helpful if you provide me some information regarding this problem. Thanks.
the short answer is: the command/feature is not supported in Packet Tracer (it is one of the many limitations of this simulator)...
Thanks ,
hope this type of limitations will be removed from CPT in it's coming versions.
