Trunking issue between Cisco Switches ( 3750 and 6509 )
dayibqalib
HI Everyone
Ports aren't coming up between 3750 and Cisco 6509 Switches:
Cable used:  UTP 5e cable
Port Configuration on both ends are shown below:
6509 Switch port config
interface GigabitEthernet1/34
no ip address
logging event link-status
speed 100
switchport
switchport trunk native vlan 999
switchport trunk allowed vlan 380,999
switchport mode trunk
6509
APW-BTI-00-DR-ASW-01#show interfaces gigabitEthernet 1/34
GigabitEthernet1/34 is down, line protocol is down (notconnect)
  Hardware is C6k 1000Mb 802.3, address is 0012.803e.c191 (bia 0012.803e.c191)
  MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec,
     reliability 255/255, txload 0/255, rxload 0/255
  Half-duplex, 100Mb/s
  input flow-control is off, output flow-control is desired
  Clock mode is auto
3750 port config
interface GigabitEthernet1/0/31
speed 100
end
3750
GigabitEthernet1/0/31 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 001c.0ecc.121f (bia 001c.0ecc.121f)
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Auto-duplex, 100Mb/s, media type is 10/100/1000BaseTX
Please advice where the issue might be and thanks in advance
If the speed and duplex settings are set to default, MDI/MDI-X will kick in and when this happens straight-through or cross-over cables won't make a difference as long as each pins are terminated correctly.
5 Replies 5
Leo Laohoo
Where is the encapsulation command:  switchport trunk encapsulation [dot1q/isl] for both sides?
speed 100
Remove this line.  This is an old-school method of doing something stupid.
HI Leo
Thanks for you response, I have removed the Speed 100, however  I am not able to add the
switchport trunk encapsulation  dotq  on the 6509 switch it won't allow my to type encapsulation dot1q.
Could you please also let me know what the correct cable connection should be at the moment I am using cat5e.
Many thanks
 I am not able to add the switchport trunk encapsulation  dotq  on the 6509 switch it won't allow my to type encapsulation dot1q.
There are certain line card that won't accept the command because the default value is "dot1q" for encapsulation.
On the 3750, do a TDR test on the cable.
HI Lao
is mandatory to use a crossover cable between 6509 and 3750 or can it autosense like some newer switches do ?
