Jabber for iphone not ringing incoming call while sleepmode
5959
Hi guys,
My customer using jabber
But Not ringing call while the phone is sleep mode
Since 2021 nov
What am I should check on cucm or exp imp
Please metion anything
Igor Lukic
Hi @5959,
this sounds like an issue with Apple Push Notifications. Have you gone through this guide to implement it?
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/push_notifications/cucm_b_push-notifications-deployment-guide.html
Please also consult this document for further information regarding required CUCM, IM&P and Expressway versions:
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cucm/push_notifications/APNSUpdates.pdf
Best regards,
Igor
Igor Lukic
Hi @5959,
Best regards,
Igor
Hi @igor
Thanks for your support
The new Iden Trust certificate was uploaded to cucm,
so I thought it would naturally play its role,
but Tomcat, Noti, etc I didn't redo many services.
It seems that the ASPN server failed to send a notification.
As a result of checking after the service re-execution operation, it was confirmed that the jabber call was received in Sleep mode.
Best regards,
Ok
Hi @5959,
I am really glad that you were able to solve the issue! Thanks a lot for marking my post as a solution!
Best regards,
Igor
