Accessing and Managing CIMP properties
dkartio20
Am working on a application the will help in moving a user from one CUCM server to another, this includes all there CIMP information (buddy list, etc).
We use AXL to handle all the CUCM managed information, provisioning/deprovisioning of devices, etc.
But AXL does not access CIMP information, I have seen EPAS Soap being used, but am confused by that process, if that can be used.
To use EPAS, you need to log in as the intended user to get a proper session-key,  that is not an option for us, since the credentials are sync'ed with AD.
What is the best way to get to a user's contact list, extract that information, and import it a different server.
Also, how can you handle a user's CCMCIP group (adding and removing them to a group)?
dstaudt
(Note as this question is mainly in regards to IM & Presence APIs, there is an IM&P question specific forum here: Unified Presence)
The EPASSoap API (aka 'Client Configuration Web Service') is probably what you want to look at.  This API can be used either with individual end-user credentials (requiring the user password) or by 'proxy' by loging in an 'application user' and then creating a session on behalf of an end-user (requiring only the user user id.)  From the section 'Login and Authentication':
The Client Configuration Web Service supports the following login scenarios:
The client application sends a username and password for an end user in the login request for
authentication, and Cisco Unified CM IM and Presence returns a unique session key for the
end user.
The client application logs in to Cisco Unified CM IM and Presence as an "application user"
using an application username and password. The client application can then log in an end
user by passing the session key for an application user, and the username for an end user
in the login request; a unique session key for the end user is returned.
Cisco DevNet: UC Manager IM & Presence APIs - Client Configuration Web Service - Latest Version
See also the info in the Login Request / Client-Type section for more info needed to implement the proxy login.
You should be able to use the lookup/get/add-contact requests from the API to accomplish the task.
dstaudt
end user.
Thanks David.
I found this exact passage after posting this on the forums, and after some serious trial and error got this [semi] working.
We are currently trying to figure out how to automatically move all the user's IM roster [contact] list to a different CUCM cluster.
If you have any insight, I did ask this question in the Unified-Presence forum.
Thanks again for your help
Have you tried using <get-non-presence-aware-contacts> to get a full contact list from the old IM&P server, and then using <add-contact> (logging into the new IM&P server) to re-add..?
The <add-contact> does work fine (at times, see below).  Once we log in as an application user, then get a session-key for a particular user.
But the <get-non-presence-aware-contacts>, returns interesting results.  For the this userpic1.png
I get this return
For this user
I get this return
Just for clarification, the CUPS server is version 10.5.2 and I am calling the the epas:soap v80 extension.
BTW:  if I call the <add-contact> to the user that has 5 contacts and 1 watcher, I get the following error
