Envelope Issues When Passing to PAWS
caten
I am attempting to use PERL to communicate with the PAWS API. As an example, I will be using the getInactiveVersion envelope:
<?xml version="1.0" encoding="UTF-8"?>
    <soapenv:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:namesp2="http://www.w3.org/2005/08/addressing" xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
        <soapenv:Header>
            <wsa xmlns:wsa="http://www.w3.org/2005/08/addressing">
                <wsa:MessageID xsi:type="xsd:string">
                    uuid:63e5d8ca-dcac-40af-916b-d32ec3382d0f
                </wsa:MessageID>
                <wsa:ReplyTo>
                    <wsa:Address xsi:type="xsd:anyURI">
                        http://www.w3.org/2005/08/addressing/anonymous
                    </wsa:Address>
                </wsa:ReplyTo>
                <wsa:Action xsi:type="xsd:string">
                    getInactiveVersion
                </wsa:Action>
            </wsa>
        </soapenv:Header>
        <soapenv:Body>
            <getInactiveVersion xmlns="http://services.api.platform.vos.cisco.com" xsi:nil="true" />
        </soapenv:Body>
    </soapenv:Envelope>
When I use this envelope, I get the following error:
Error: A required header representing a Message Addressing Property is not present
I have attempted using several envelopes. The I found that the following envelope worked in when I used curl in a bash script, but I couldn't get it to work in PERL:
#!/bin/bash
request='<?xml version="1.0" encoding="UTF-8"?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
    <soapenv:Header xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing">
        <wsa:Action>getInactiveVersion</wsa:Action>
        <wsa:MessageID>uuid:63e5d8ca-dcac-40af-916b-d32ec3382d0f</wsa:MessageID>
        <wsa:ReplyTo>
            <wsa:Address>http://www.w3.org/2005/08/addressing/anonymous</wsa:Address>
        </wsa:ReplyTo>
        <wsa:To></wsa:To>
    </soapenv:Header>
    <soapenv:Body>
        <getInactiveVersion xmlns="http://services.api.platform.vos.cisco.com"/>
    </soapenv:Body>
</soapenv:Envelope>'
curl --silent -k -u 'xxxxxxx:yyyyyyyy' -H "Content-type: text/xml;" -d "$request" "https://cucm/platform-services/services/VersionService"
Could anyone help me out in identifying the issue with the Error I am seeing when running the request via PERL?
Thanks.
caten
One thing I forgot to mention. There are times, after playing around with the envelope a bit, that I can get a response which states:
$VAR1 = {
          'getInactiveVersionResponse' => {
                                          'return' => bless( {
                                                             'version' => undef,
                                                             'remoteMessages' => bless( {
        'info' => 'false',
        'messageParams' => 'wsa.replyto',
        'warning' => 'false',
        'messageKey' => 'error.validation.required',
        'error' => 'true',
        'messageType' => 'internal.message.error'
        }, 'RemoteMessage' ),
                                                             'result' => 'internal.request.failed'
                                                           }, 'VersionResponse' )
caten
I grabbed some of the PAWS trace as well:
2016-03-23 12:12:20,752 INFO  [http-bio-443-exec-28] services.VersionService.getInactiveVersion -
2016-03-23 12:12:20,753 INFO  [http-bio-443-exec-28] services.VersionService.getInactiveVersion - *** Starting service ***
2016-03-23 12:12:20,753 INFO  [http-bio-443-exec-28] services.RemoteService.isValidRequest - replyTo = null
2016-03-23 12:12:20,754 INFO  [http-bio-443-exec-28] services.RemoteService.isValidRequest - messageID = null
2016-03-23 12:12:20,754 INFO  [http-bio-443-exec-28] api.Message.<init> - Message key = [error.validation.required]
2016-03-23 12:12:20,754 INFO  [http-bio-443-exec-28] api.Message.<init> - Message type = [internal.message.error]
2016-03-23 12:12:20,754 INFO  [http-bio-443-exec-28] element.RemoteMessage.<init> - Message param[0] = [wsa.replyto]
2016-03-23 12:12:20,755 INFO  [http-bio-443-exec-28] services.VersionService.getInactiveVersion - *** Ending service ***
It looks like the replyTo and messageID aren't getting passed.
dstaudt
If the XML request as shown is representative of the actual request, I found the following issues:
        <soapenv:Header>
            <wsa xmlns:wsa="http://www.w3.org/2005/08/addressing"> <-- invalid sub-element <wsa>
                <wsa:MessageID xsi:type="xsd:string"> <-- invalid new lines and whitespace
                    uuid:63e5d8ca-dcac-40af-916b-d32ec3382d0f <-- invalid new lines and whitespace
                </wsa:MessageID>
                <wsa:ReplyTo>
                    <wsa:Address xsi:type="xsd:anyURI"> <-- invalid new lines and whitespace
                        http://www.w3.org/2005/08/addressing/anonymous<-- invalid new lines and whitespace                    </wsa:Address>
                </wsa:ReplyTo>
                <-- Missing <wsa:To></wsa:To> element
                <wsa:Action xsi:type="xsd:string"> <-- invalid new lines and whitespace
                    getInactiveVersion <-- should be 'urn:getInactiveVersion'; invalid new lines and whitespace
                </wsa:Action>
            </wsa> <-- invalid sub-element <wsa>
        </soapenv:Header>
        <soapenv:Body>
        </soapenv:Body>
    </soapenv:Envelope>
The correct version (tested on CUCM 10.5)
        <soapenv:Header xmlns:wsa="http://www.w3.org/2005/08/addressing">
                <wsa:MessageID xsi:type="xsd:string">uuid:63e5d8ca-dcac-40af-916b-d32ec3382d0f</wsa:MessageID>
                <wsa:ReplyTo>
                    <wsa:Address xsi:type="xsd:anyURI">http://www.w3.org/2005/08/addressing/anonymous</wsa:Address>
                </wsa:ReplyTo>
                <wsa:Action xsi:type="xsd:string">urn:getInactiveVersion</wsa:Action>
                <wsa:To></wsa:To>
        </soapenv:Header>
        <soapenv:Body>
        </soapenv:Body>
    </soapenv:Envelope>
