addCommonPhoneConfig ignoring vendorConfig info?
JasunKAR
Howdy!  Adding everything I need through a python script to spin up a site in CUCM.  When adding a common phone config it seems to be ignoring a vendorConfig piece I want to modify.
# Create commonPhoneConfig siteCode_locationType Common Phone Profile
commonPhoneConfig = {
    'name': ( globalName + ' Common Phone Profile' ),
    'description': ( globalName + ' Common Phone Profile' ),
    'dndOption''Ringer Off',
    'dndAlertingType''Beep Only',
    'alwaysUsePrimeLine''Default',
    'alwaysUsePrimeLineForVoiceMessage''Default',
    'vendorConfig':
            'sshAccess''1',
            'lineMode''1'
It all adds great with no issues.  But the lineMode/SSH doesn't get toggled.  In XML it works fine:
<commonPhoneConfig>
    <name>TEST2 Common Phone Profile</name>
    <description>TEST2 Common Phone Profile</description>
    <dndOption>Ringer Off</dndOption>
    <dndAlertingType>Beep Only</dndAlertingType>
        <vendorConfig>
            <sshAccess>1</sshAccess>
            <lineMode>1</lineMode>
        </vendorConfig>
</commonPhoneConfig>
That works fine.  Just not the python option.  Thoughts?
Also, all the lines have ' and , after then but this post seems to be combining them into ; /shrug
Alexander Stevenson
I'm not a CUCM expert but I found some other discussions here on the Cisco Community Forums, which may be helpful:
Hope this helps!
Alexander Stevenson
Hope this helps!
Thanks alex you pointed me in a good direction.  I got it to work through AXL using this code from that second link:
lineMode = etree.Element( 'lineMode' )
lineMode.text = '1'
vendorConfig = []
vendorConfig.append( lineMode )
xvcType = client.get_type( 'ns0:XVendorConfig' )
commonPhoneConfig[ 'vendorConfig' ] = xvcType( vendorConfig )
The python script to create the commonPhoneConfig now properly sets the line mode.  Appreciate the help!
