Showing results forĀ
Search instead forĀ
Did you mean:Ā
AXL API Ring setting (Phone Active) "Beep Only"
Ring setting (Phone Active) "Beep Only" How do i set this in AXL API?
I have found  XPhoneLine.setRingSetting(value); but this only sets for Idle.
Call Manager Version = ( 10.5.2.12901(1) )
TDoan
Hi Brian,
You can use updatePhone (AXL API) to update the ring setting
Example:
        <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/10.0">
            <soapenv:Header/>
                <soapenv:Body>
                   <ns:updatePhone sequence="1">
                       <uuid> + ADeviceUId + </uuid>
                       <Lines>
                          <line>
                            <uuid> + ALineUUId </uuid>
                            <ringSetting>Ring</ringSetting>    ----> You need to set a value here (Ring, Flash Only or Ring One, ...
        This is set for Ring Setting (Phone Idle)
                            <consecutiveRingSetting>Beep Only</consecutiveRingSetting>  ---> This is set for Ring Setting (Phone        Active)
                          </line>
                       </lines>
                   </ns:updatePhone>
                </soapenv:Body>
         </soapenv:Envelope>
Hope that would help you.
Thuy Doan
TDoan
Hi Brian,
Example:
            <soapenv:Header/>
                <soapenv:Body>
                       <Lines>
                          <line>
                          </line>
                       </lines>
                   </ns:updatePhone>
                </soapenv:Body>
         </soapenv:Envelope>
Thuy Doan
consecutiveRingSetting <-- this was key
Not sure why the names are so different from the GUI
thanks Thuy Doan
