AXL Authentication Cookies
Gordon Ross
Level 9
Level 9
The docs say that you can use the JSESSIONID cookie to re-use an authentication session. Yet in testing on CUCM 11.5, I find that this doesn't work. Instead, you have to use the new(er) JSESSIONIDSSO cookie.
If you send just the SSO cookie, things work. Send only a (valid) JSESSIONID cookie, and you get a wonderful 401 error.
Have the docs not been updated, or is this a bug?
GTG
Please rate all helpful posts.
dstaudt
Thanks for catching this, we'll take and look at get this updated...
James Adam
How are you able to validate that this is working? I have tried sending the JSESSIONID and/or the JSESSIONIDSSO cookie with a subsequent request and each time I get back a new set of cookies with my response. If I drop the auth header and send a request with cookies from a previous valid request I get a 401 error. (using CUCM 11.5)
Note, the JSESSIONIDSSO cookie will expire after about 30 minutes.
What you describe should work:
- Make a standard request with 'Authorization' header
- Extract the 'Set-Cookie' response header for JSESSIONIDSSO
- On subsequent requests, do not include Authorization, but do include a 'Cookie' header containing the content the full JSESSIONIDSSO:
Cookie: JSESSIONIDSSO=2723FD93559E7FA7E17F0E7958D13; Path=/; Secure; HttpOnly
Hey thanks for the quick response. I realized that I was sending a Set-Cookie header with my subsequent requests instead of a Cookie header. Fixed that and it works as expected now.
+1 dstaudt
