07-07-2017 10:32 AM
I'm calling "listPhone" with filter 'abc%' for devicePoolName and it returns all phones including ones for which the device pool name doesn't match. I can filter by "name" without any issues. Is it broken or am I missing something?
07-07-2017 11:05 AM
I'm using python suds but here's the raw XML going out:
<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:ns0="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns1="http://www.cisco.com/AXL/API/9.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
<SOAP-ENV:Header/>
<ns0:Body>
<ns1:listPhone>
<searchCriteria>
<devicePoolName>bc%</devicePoolName>
</searchCriteria>
<returnedTags>
<name></name>
</returnedTags>
</ns1:listPhone></ns0:Body></SOAP-ENV:Envelope>
07-13-2017 11:36 AM
This appears to be working OK on my 10.5 system:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/9.1">
<soapenv:Header/>
<soapenv:Body>
<ns:listPhone>
<searchCriteria>
<devicePoolName>abc1%</devicePoolName>
</searchCriteria>
<returnedTags>
<name/>
<devicePoolName/>
</returnedTags>
</ns:listPhone>
</soapenv:Body>
</soapenv:Envelope>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
<soapenv:Body>
<ns:listPhoneResponse xmlns:ns="http://www.cisco.com/AXL/API/9.1">
<return>
<phone uuid="{1B7A5861-A2DE-65B9-46C7-47D6C06703A4}">
<name>BOTDSTAUDT</name>
<devicePoolName uuid="{ED0A1AC1-1656-D869-DD30-AADDDB87434A}">abc1</devicePoolName>
</phone>
</return>
</ns:listPhoneResponse>
</soapenv:Body>
</soapenv:Envelope>
If you are running on CUCM 9.1 and still experiencing the problem, I would recommend opening a DevNet Developer Support ticket so we can investigate via the detailed AXL logs and escalate with engineering if needed: Cisco DevNet: DevNet Developer Support
