AXL phone service running over HTTPS
upchaurasia
If our AXL phone service is running on HTTPS then how phone will get the certificate from our server.Is there any specific configuration required to access phone service over https from phone?
Umesh
TDoan
Level 3
Level 3
Hi Umesh,
You need to set Authentication User Name, Password from HTTPS component.
Create an Application user with the rights to execute AXL queries
Ensure that the AXL service is enabled in the Application Suite server.
Please go this link as below to get more details.
https://developer.cisco.com/media/manager-xml-developer-guide/index.html?versioning.html
Thuy Doan
Hi Doan,
Thanks for reply. Actually u have posted for the way to connect Application to CUCM AXL service over https. This part we are already doing.
My query was if we will deploy our AXL application on Tomcat over https then how phone will get our application server certificate.
My current setup is-
Phone------------------------->Application deployed in Tomcat------------------>CUCM AXL Web Service
                HTTP        HTTPS
Now I want to enable HTTPS between phone & my application also-
                HTTPS        HTTPS
Do I need to take care of any specific configuration to download application server certificate on phone?
Umesh
Hi Umesh,
What language are you using to write your application?. Could you please tell me more details what you want to get from Phone/Device?
I do not use the server certificate in my application. I only need to implement the certificate-related stuffs required for sending request via https.
Thuy Doan
I am using JAVA. I have create my application server certificate using keytool.
Other details I will write in next post.
Umesh
