05-25-2015 12:28 AM
I'm a newbe with axl programming.
I have problem to create a addphone I get a error 500.
Everthing that I try don't work
I have CUCM version 8.6
All in in c#
Casn any one help me or point me in the write direction.
Thanks.
My code is:
private void ADDPHONE()
//string version = Properties.Settings.Default.CUCMVersion;
string version = "8.5";
string soap = "<soapenv:Envelope xmlns:soapenv=\"http://schemas.xmlsoap.org/soap/envelope/\" xmlns:ns=\"http://www.cisco.com/AXL/API/8.5\">\n";
soap += "<soapenv:Header/>\n";
soap += "<soapenv:Body>\n";
soap += "<ns:addPhone sequence=\"?\">\n";
soap += "<phone >\n";
soap += "<name>SEP000000123456/name>\n";
soap += "<description>IP Phone Test</description>\n";
soap += "<product>Cisco 7961G-GE</product>\n";
soap += "<class>Phone</class>\n";
soap += "<protocol>SCCP</protocol>\n";
soap += "<protocolSide>User</protocolSide>\n";
soap += "<callingSearchSpaceName uuid=\"?\">DN_Global</callingSearchSpaceName>\n";
soap += "<devicePoolName uuid=\"?\">Default</devicePoolName>\n";
soap += "<lines>\n";
soap += "<line ctiid=\"?\">\n";
soap += "<index>1</index>\n";
soap += "<label>?</label>\n";
soap += "<display>?</display>\n";
soap += "<dirn uuid=\"?\">\n";
soap += "</dirn>\n";
soap += "<ringSetting>Ring</ringSetting>\n";
soap += "<consecutiveRingSetting>Use System Default</consecutiveRingSetting>\n";
soap += "<e164Mask></e164Mask>\n";
soap += "<mwlPolicy>Use System Policy</mwlPolicy>\n";
soap += "</line>\n";
soap += "</lines>\n";
soap += "<phoneTemplateName uuid=\"?\">Standard 7961G-GE SCCP</phoneTemplateName>\n";
soap += "<speeddials>\n";
soap += "<speeddial>\n";
soap += "<label>Jan Test</label>\n";
soap += "</speeddial>\n";
soap += "</speeddials>\n";
soap += "<services>\n";
soap += "<service>\n";
soap += "<telecasterServiceName uuid=\"?\">Mobility</telecasterServiceName>\n";
soap += "<name>Mobility</name>\n";
soap += "</service>\n";
soap += "</services>\n";
soap += "<softkeyTemplateName uuid=\"?\">Standard User</softkeyTemplateName>\n";
soap += "<enableExtensionMobility>false</enableExtensionMobility>\n";
soap += "</phone>\n";
soap += "</ns:addPhone>\n";
soap += "</soapenv:Body>\n";
soap += "</soapenv:Envelope>\n";
Logging.Text += "---------|AXL Request|---------\n\n";
Logging.Text += soap + "\n\n";
#region AXL SOAP
try
byte[] soapBytes = Encoding.UTF8.GetBytes(soap);
ServicePointManager.ServerCertificateValidationCallback += delegate { return true; };
HttpWebRequest httpRQ = (HttpWebRequest)HttpWebRequest.Create(string.Format(@"https://xxx.xxx.xxx.xxx:8443/axl/"));
httpRQ.ProtocolVersion = System.Net.HttpVersion.Version10;
httpRQ.Credentials = new NetworkCredential("AXLAdmin", "AXLPassword");//Callmanager gebruikersnaam / password
httpRQ.Method = "POST";
httpRQ.ContentType = "text/xml; charset=utf-8";
httpRQ.Accept = "text/xml";
httpRQ.Headers.Add("SOAPAction: 'CUCM:DB ver=" + version + "'");
httpRQ.ContentLength = soapBytes.Length;
//Send the xml soap to cucm
Stream stm = httpRQ.GetRequestStream();
stm.Write(soapBytes, 0, soapBytes.Length);
stm.Close();
//Build the xml response
XDocument responcedoc = new XDocument();
HttpWebResponse responce = httpRQ.GetResponse() as HttpWebResponse;
Stream responcedata = responce.GetResponseStream();
StreamReader responsereader = new StreamReader(responcedata);
Logging.Text += "\n---------|AXL Response|---------\n\n";
XDocument respdoc = XDocument.Load(responsereader);
Logging.Text += respdoc + "\n";
soap = null;
catch (Exception ex)
Logging.Text += "\n";
Logging.Text += "\n---------|AXL Error|---------\n\n";
Logging.Text += string.Format("\n" + DateTime.Now + ":: ERROR :: Message: {0}\n", ex.Message);
#endregion
Jan Meeling
05-25-2015 05:04 PM
Please go to this website to have a look at. There are some samples as adding phone, line, user...
Administrative XML (AXL) Developer Cookbook
Thuy Doan
05-26-2015 01:43 AM
Hi Thuy,
I have testen some examples of it but it don’t work.
Thanks for your quick response
Jan Meeling
