06-18-2014 08:04 AM
Hi Team,
I'm getting below exception for AXL - listPhoneByName. Could you please provide me the new AXL API request format of Call Manager 10.x version
********************Data********************
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"><SOAP-ENV:Body><axlapi:listPhoneByName xmlns:axl="http://www.cisco.com/AXL/1.0" xmlns:axlapi="http://www.cisco.com/AXL/API/1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.cisco.com/AXL/API/1.0 axlsoap.xsd"><searchString>%</searchString></axlapi:listPhoneByName></SOAP-ENV:Body></SOAP-ENV:Envelope>
*********************Data End********************
HTTP Response:
<?xml version='1.0' encoding='utf-8'?><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"><soapenv:Body><soapenv:Fault xmlns:axis2ns2="http://schemas.xmlsoap.org/soap/envelope/"><faultcode>axis2ns2:Client</faultcode><faultstring>The endpoint reference (EPR) for the Operation not found is https://10.1.1.1/axl/services/AXLAPIService and the WSA Action = CUCM:DB ver=8.0 listPhoneByName</faultstring><detail /></soapenv:Fault></soapenv:Body></soapenv:Envelope>
Rajesh
06-18-2014 11:51 PM
Hi Rajesh,
I think your error is here,===> http://www.cisco.com/AXL/API/1.0
when you using the axl interface to request info for cucm 10. I think you can using the following info to request:
<axl:getUser xmlns:axl=\"http://www.cisco.com/AXL/API/10.0\"
xsi:schemaLocation=\"http://www.cisco.com/AXL/API/10.0 http:// ccmserver/schema/axlsoap.xsd\"
sequence=\"123ee45\">
<userid>test</userid>
</axl:getUser>
Perhaps may help you
06-19-2014 06:20 AM
Hi Chao,
Thank you very much for the response. Could you please point me the 10.x version AXL api's request and response format link details.
Rajesh
06-19-2014 06:43 PM
Hi Rajesh,
This link is the cisco axl interface guide. https://developer.cisco.com/media/manager-xml-developer-guide/index.html?versioning.html
In this guide, cisco provide the detail of axl api's request and response info.
